Hi John,
Seems that you may be missing some files.
Did you apply the 3.0h update file to a much earlier version of PEBBLE?
The M2/X2 PICAXE chips were added back in version 3.0e:
If it is only the 40X2 you have been missing these (attached) files. You can try and insert them into the PEBBLE/images folder
If that fixes the problem then I suspect you need to go an download the full PEBBLE V3.0g program zip file (See links in post 1 of this thread) and then apply the V3.0h updater files.
I notice that Rev Ed is still only hosting V2.4
While I recognise that they have been busy with M2 releases and updated X2 parts etc V2.4 does not include the latest PICAXE parts and other enhancements of recent.
Technical, hippy - any intent to upgrade the hosted version of PEBBLE soon?
Do you also have the same problem with the 18M2?3.0e 27 Sept 2010
Added PICAXE 18M2
Added PICAXE 20X2
Added PICAXE 28X2
Added PICAXE 40X2
Added 74C922 4x4 matrix Keypad Encoder
Added 74C923 4x5 matrix Keypad Encoder
Added 74HC04 / 74HC05 Hex Inverter IC
