Maybe you have made a more permanent acceptance as an option.
IC||121|210|1|PICAXE08M2|U?|||DIP8|IC||DIP8_1
Terminal||65|116|1||TS?||3|4|PGM SoSiG||terminal_431
Resistor|10000|105|149|1|Resistor|R?||0||IC||
Resistor|22000|105|341|1|Resistor|R?||1||IC||
Wire||76|180|11||11|#FF0000|3|11||10|
Wire||101|209|21||11|#3253FF|3|11||10|
IC||471|210|1|DIP10 Relay|U?|||DIP8|IC||DIP8_1
Terminal||308|116|1||TS?||6|3|RTC DS3231||terminal_361
Wire||128|402|21||11|#FF0000|2|11||10|
Terminal||523|363|1||TS?||2|4|12V||terminal_421
Wire||317|44|21||11|#000000|2|11||10|
Wire||128|44|21||11|#000000|2|11||10|
Note||50|33|1||||1||GND||NOTEPAD_11
Note||47|445|1||||1||5V||NOTEPAD_11
Capacitor||119|211|4|Capacitor|C?||3|4|||cap_434
Resistor|4700|394|47|2|Resistor|R?||1||IC||
Wire||211|152|11||11|#FF9900|6|11||10|
Wire||184|171|12||11|#FF9900|8|11||10|
Miscell||576|281|1||XX?||1|33|Miscell||misc_33
Miscell||576|198|1||XX?||1|33|Miscell||misc_33
Resistor|4700|367|47|2|Resistor|R?||1||IC||
Resistor|4700|421|47|2|Resistor|R?||1||IC||
Note||375|225|1||||1||SDA||NOTEPAD_11
Wire||344|402|21||11|#FF0000|2|11||10|
Wire||344|209|21||11|#FF0000|3|11||10|
Wire||157|183|13||11|#FFFF00|12|11||10|
Resistor|180|455|342|1|Resistor|R?||0||IC||
Wire||184|372|11||11|#FFFF00|10|11||10|
Wire||532|402|21||11|#FF0000|2|11||10|
LED|0|561|389|3|LED|LED?|1|||IC||led_13
Wire||613|44|21||11|#000000|9|11||10|
Wire||425|209|21||11|#A233C3|3|11||10|
Note||400|255|1||||1||SLC||NOTEPAD_11
Wire||211|317|11||11|#A233C3|8|11||10|
Resistor|22000|590|397|1|Resistor|R?||0||IC||
Capacitor||320|93|1|Capacitor|C?||1|3|||cap_311
BREADBOARDSTYLE=BB4
SHOWTHETOPAREA=false
I am pretty sure this error message doesn't affect the operation of the application that I have been able to determine but the fact that it's there bothers me since I cannot seem to find the line of the html file or any of the javascript files that are causing the error message to appear but in my console window whenever I load the PEBBLE_for_ff.html file I get the following error message "images%20/%20transparent1x1.gif:1 GET file:///P:/Electronics/PEBBLE/images%20/%20transparent1x1.gif net::ERR_FILE_NOT_FOUND" Any idea where this is coming from? From the looks of it somewhere there is a call to load the file /images/transparent1x1.gif file but the command has spaces after the word images and before the word transparent But for the life of me I cannot locate this line in any of the files. Is it being built dynamically? Please help.
I did discover that one of the javascript files had spaces in the command. not sure if I accidently stuck them in there while editing files or not. I will have to double check that and get back to you about it. But I did fix my copy so I am not getting the error messages anymore. Also I finished getting the print routine changed so that it only prints the protoboard and not all the other stuff. (menus, title, instructions, etc.) I added jquery to the file using the google hosted library link. I can send you the zip of what I have if you want to take a look at it in case it is something you are interested in going further with. I was thinking about creating a menu that lets the user choose which parts of the screen they want to print i.e. the offboard areas, the parts bin, etc. Anyway Just thought I would let you know and again say thanks for a cool app. saves me alot of time when going from a schematic to a prototype board.
A question to the Pebble Moderator, how do I make the leads on the images of resistors longer? I am using Pebble to draw layouts on veroboard but the large resistor outline seems to be only the size of a half watt type. I need to use 1W and 5W types which would cover a minimum of eight and 12 holes respectively. I have had to resort to using wire images to get the lengths I need. Otherwise Pebble has been very useful for devising the best layout before heating the soldering iron.
.resistorDiv, .dipPackageDiv, .diodeDiv, .discretePackageDiv, .terminalDiv,
.capacitorDiv, .wireTD, .dipswDiv, .switchDiv, .transistorDiv, .miscellDiv,
.sliderDiv, .sliderOuterDiv, .noteDiv, .noteOuterDiv, .fourDDiv
{-webkit-filter: drop-shadow(4px 6px 6px #4e4e4e);filter: drop-shadow(4px 6px 6px #4e4e4e);}
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd">
Resistor|10000|231|47|2|Resistor|R?||2||IC||
IC||310|210|1|08M2|U?|||PICAXE08M2|IC||PICAXE08M2_1
Diode|0|508|148|1||CR?||2|1|IC||diode_121
LED|0|399|141|3|LED|LED?|2|||IC||led_23
Terminal||227|143|1||TS?||3|4|||terminal_431
Capacitor||285|211|4|Capacitor|C?||3|5|||cap_534
Wire||317|44|21||11|#CC6633|2|11||10|
Wire||317|402|21||11|#FF0000|2|11||10|
Wire||372|317|11||11|#FF9900|3|11||10|
DIPSw||121|209|1||SW?||10||DIPSw||dipsw_101
Switch||66|7|2||SW?|1||1|Switch||switch_112
Switch||43|205|4||SW?|1||2|Switch||switch_214
Transistor|BC559|27|100|5|Transistor|Q?|||1|IC||transistor_15
Transistor|BC559|132|45|4|Transistor|Q?|||1|IC||transistor_14
Miscell||454|323|1||XX?||1|1|||misc_1
Resistor|22000|231|212|2|Resistor|R?||2||IC||
Wire||265|125|11||11|#FFFF00|3|11||10|
Wire||238|345|11||11|#3253FF|4|11||10|
Resistor|390|419|47|2|Resistor|R?||2||IC||
Wire||292|180|11||11|#000000|1|11||10|
Wire||292|317|11||11|#FF0000|1|11||10|
Wire||505|402|21||11|#FF0000|2|11||10|
Resistor|10000|445|185|2|Resistor|R?||3||IC||
Wire||451|44|21||11|#CC6633|2|11||10|
Slider||546|334|1||XX?||1|2| ||floating_12
Note||700|43|1||||2||NOTE:<br> Not a Functional Circuit<br> For Testing Only.||NOTEPAD_21
Slider||624|333|2||XX?||1|2| ||floating_22
Transistor|BC559|103|163|2|Transistor|Q?|||1|IC||transistor_12
Diode|0|501|46|2||CR?||2|2|IC||diode_222
DIPSw||550|208|1||SW?||4||DIPSw||dipsw_41
FourD||192|452|1||XX?||1|2|FourD||fourd_2
BREADBOARDSTYLE=BB7
/* ORIGINAL FUNCTION CODE */
function openDialog(e)
e = getEvent(e);
var target = getEventSource(e);
// Find the element with the "parttype" attribute
// which will become the target element.
if(getElementAttribute(target, "parttype"))
// Do nothing...
while(target = getElementParent(target)) // Expected a conditional expression and instead saw an assignment. rhb.20241221
break;
/* Replacement Code */
function openDialog(e) {
e = getEvent(e);
while (target && !getElementAttribute(target, "parttype")) {
target = getElementParent(target);
var wireColors = "#000000,#CC6633,#FF0000,#FF9900,#FFFF00,#00A060,#3253FF,#A233C3,#999999,#FFFFCC,#B87333".split(",");
var wireColorsCSS = "black,brown,red,orange,yellow,green,blue,violet,gray,white,bare".split(",");
/* Original Code Example – copied as is from file */
<div id="CreditsDiv" class="creditsDiv">
<script language="javascript">document.writeln(_("PEBBLE by "));</script>
<a target="newwindow" href="http://www.picaxeforum.co.uk/member.php?u=46375">WestAust55</a>.
<br>
<script language="javascript">document.writeln(_("Concept based on Virtual Breadboard by "));</script>
<a target="newwindow" href="http://www.musicfromouterspace.com">Ray Wilson</a>
<br>
<script language="javascript">document.writeln(_("This is a work in progress."));</script>
<br>
<script language="javascript">document.writeln(_("Visit the "));</script>
<a target="newwindow" href="http://www.picaxeforum.co.uk/">PICAXE forum</a>
<script language="javascript">document.writeln(_("for information on the PICAXE"));</script>
<br>
<script language="javascript">document.writeln(_("micro-controller chips."));</script>
</div>
<div id="ScnPrntDiv" class="scnprntDiv">
<script language="javascript">document.writeln(_("Before printing the screen "));</script>
<a target="newwindow" href="support/printhelp.html">
<script language="javascript">document.writeln(_("enable browser printing"));</script></a>
<script language="javascript">document.writeln(_(" of background colours and images"));</script>
</div>
/* New Code Example */
<div id="ScnPrntDiv">
{{Before printing the screen}},
<a target="_blank" href="support/printhelp.html">
{{enable browser printing}}
</a>
{{of background colours and images}}.
</div>
<div id="CreditsDiv">
{{PEBBLE by}}
<a href="http://www.picaxeforum.co.uk/member.php?u=46375" target="_blank">
WestAust55
</a>.
{{Concept based on Virtual Breadboard by}}
<a href="http://www.musicfromouterspace.com" target="_blank">
Ray Wilson
</a>.
{{Visit the}}
<a href="http://www.picaxeforum.co.uk/" target="_blank">
PICAXE Forum
</a>
{{for information on the PICAXE}} {{micro-controller chips}}.
<p class="center">{{This is a work in progress}}!</p>
</div>
