sample rate
eitan
hello
I need to sample my sensor 10-15 times in a second (sample and send via SEROUT(baud rate is TBD)).
IS 18M2 or 08M2 running 4MHz can do that? - how to calc how many sample per sec I can get?\
another thing, what is the ADC input impedance for 08M2 or 18M2?
BR
Eitan
srnet
That would depend on the sensor, and how long it takes to read it.
Plus how much data you are going to be sending via serial and what the baud rate is.
g6ejd
Sampling at 15 / sec (worst case in your specification) requires a budget of 66mS / sample.
Allow some time for pre-processing in your code of the same, lets say 5mS
Allow some time to get the sample out on the serial port at 9600baud say 10mS per sample (1/9600 * 10 bits x 10 characters e.g. SEROUT ("V = 3.10 v")
Allow some time to go back around the loop to start the process again and do some simple tests, like are all samples complete, has the routine finished, lets say 5mS for that
Leaving a total budget of 66 - 5 - 10 - 5 = 45 mS for your ADC to do the conversion. Someone on this forum, I can't find it just now, has determined the conversion time for an 8 or 10 bit conversion, which in this example needs be as fast, if not faster than 45mS.
All this leads to a formula that you can re-arrange to give you baud rate and determine the maximum speed, or conversely fine tune all of the numbers to optimise your result for sampling speed as required. If you produced a simple draft sampling programme you can use the timing table values for each command in this forum to determine your maxmium speed. It looks like ADC conversion time is the determinant.
mrburnette
hello
BR
Eitan
The DC input impedance is in megohms. The circuit output impedance driving the ADC should be no greater than 100K but most will recommend less-than 50K. This is due to the capacitance on the AD that must charge & discharge... so there is an AC impedance concern.
EDIT: THE CORRECT PICAXE maximum serial resistor value is 10K... my error being caught by watchful members' eyes. As eluded to in other posts, this is a rule-of-thumb value provided by Microchip in their datasheet; example PIC41440B (14M2). There are lots of assumptions and gotchas that go into this number... one should be aware that other chips and especially proprietary AD chips may make other suggestions.​
With most things, one should consult the manufacturer's sensor data sheet to determine max sensor cycle time. For the PICAXE portion, I would recommend trial-n-error, the old experimental way of do doing thing. The reason I recommend a prototype is PICAXE timing is difficult to time-box because YOUR code will dictate the loop timing. I have had situations where just adding one variable had "broken" code. There are resources here to help you estimate, but only your actual code will qualify work vs failure.
:) Ray
For full adc accuracy 10K source impedance is recomended...
Absolutely, anything greater than 10k can lead to inaccuracies.
Most commands at standard clock rate take ~250uS to execute and that includes ReadADC/ReadADC10.
The longest single execution by far will be the serial out quite simply because it takes a long time to send serial data no matter how fast everything else runs.
MFB
The question was "another thing, what is the ADC input impedance for 08M2 or 18M2?" Therefore the reference to maximum series resistance could be misleading. Assuming that the read error is less than the least significant bit, for a 10-bit conversion from a 10K source, then the ADC input impedance must be at least 10,000K.
g6ejd
If you do this:
PRINT time
FOR i = 1 t0 10000
;do nothing
NEXT i
PRINT time
PRINT time
FOR i = 1 t0 10000
READAC variable
NEXT i
PRINT time
Then (second time duration - first time duration) / 10000 is good enough for how long does READADC take, do the same for READADC10 etc.
The source impedance is more to do with the acquisition and wozzit time for the ADC module in the PIC.
With direct PIC programming all the parameters can be adjusted, some even suggesting <2K source impedance depending on the other settings.
Check the PIC Data Sheet.
I don't think much of this is available through the PE.
As there is a tiddly switched capacitor involved the effective input impedance is difficult to nail so isn't necessarily as suggested by MFB.
MFB
I know its difficult to nail, that's why I said "at least 10,000K". Anything less would act (together with a 10K source impedance) as a potential divider and give an error that is greater than 0.1% of full scale.
g6ejd
It would be better to know what the sensor (output or input which-ever way you look at it) impendance is. For exmple in the unlikely case of a very high sensor impedance then the PICAXE impedance would be an important consideration for accurate readings, but in the converse case and assuming the output impedance is less or much less than the PIC, then it really does not matter that much.
Read the sensor with say a DVM and then read it with your PIC and compare the results.
It's not as simple as that MFB. You're thinking 'DC'.
Your ADC closes a little switch to charge the cap, then opens the switch and performs the conversion.
The source impedance must be low enough for that cap to charge during the acquisition time (+leakage).
As you know, current is coulombs/time so the more the number of samples per second then the greater the charge flow.
For a single sample the impedance (in conjunction with the leakage) would appear to change with time.
So, it is tricky to nail an input impedance.
The recommended source impedance varies a bit with the chosen PIC, so have a read (and have a play).
And have a look at the ADC section of PIC data sheets. I'd spend more time thinking about the recommended source impedance rather than the theoretical input impedance.
boriz
In general, the faster you want it to work, the lower the required impedance. Nothing wrong with using 1k.
In addition to Dippy's excellent description, it also depends on what the cap has been used for before. I.e. if the ADC was being used on a different pin with a different voltage just before hand. The effects of the sample & hold cap can be minimised by fitting a much larger cap (~100nF) directly on the ADC input pin but that will effect response time.
eitan
hi
Thanks for your great answers.
my sensor is some kind of 10Mohm resistor so I think I must use voltage follower/buffer using OP amp.
about how many samples per sec - if I use faster clk, will the ADC convert time will be fater too or it is not depend on clk ?
Eitan
premelec
@Dippy.... how many tiddlys in a farad? :) Those British units have me befuddly... I've only heard of tiddlys associated with winks...
.... how many tiddlys in a farad? ...
If it takes a fortnight to charge a farad, then a tiddly will only take a jiffy.
@eitan:
If your sensor really is ~10M, then you WILL need an op-amp buffer or similar.
MFB
Dippy, Thanks but I can think in AC and DC. I was just trying to give a simple explanation as to why the input impedance of the ADC was in excess of 10,000K. However, if you are able to give a precise figure I'm sure that would be appreciated.
AllyCat
The PIC A/D conversion only takes about 10us but the PICAXE instructon takes about 800us to execute. There presumably also will be many other instructions in your code with similar execution times, but you can indeed increase the clock speed to reduce them all (except for the serial comms of course).
But, if your sensor really does have a 10Mohm source impedance then the design of your voltage follower/buffer might be the limiting factor. However, the input "impedance" of the PIC is not really relevant (or even definable) as it's primarily a leakage current, largely independent of pin voltage, so Ohm's Law doesn't apply (meaningfully).
Perhaps let people know exactly what this sensor is and point us to its datasheet if you have one. That will allow members to assess if it has been interpreted right and what the best solution for it is.
Goeytex
..my sensor is some kind of 10Mohm resistor so I think I must use voltage follower/buffer using OP amp.
Possibly ... but "some kind of 10Mohm resistor" is not very specific. Certainly you can provide a better description than that.
Perhaps a part number or datasheet or a link to where you purchased it.
...about how many samples per sec - if I use faster clk, will the ADC convert time will be fater too or it is not depend on clk ?
Eitan
The conversion will be faster but conversion speed related to Picaxe ADC10 is will not be an issue. 15 times per second is no problem at all. Each conversion at 4MHz will take approximately 1.2ms. I would be more concerned with how to interface the "sensor" to the Picaxe.
eitan
hi
the sensor is home made resistor which react when you blow on it.
it is about 10Mohm when idle and go down to 1MOhm when I blow on it.
