Why not allow let to go ahead and die?...simply use two separate let and pulsout commands.
Isn't x = 10 the same as let x = 10? I use several different dialects of BASIC and I'm fairly sure haven't used let since the late 70's.
It's the command you're using when you write this: lcddata = b20I looked up the LET command in the manual but I don`t understand how to use it in this instance. Can you give an example?
low rs
lcddata = %00000010 : pulsout ENT,2 :pause 10 'move cursor home
lcddata = 144 : pulsout ENT,2 '128 + cursor moves
high RS
lcddata = b19 : pulsout ENT,2
lcddata = b20 : pulsout ENT,2
end
Yes that's right.Isn't x = 10 the same as let x = 10? I use several different dialects of BASIC and I'm fairly sure haven't used let since the late 70's.
SYMBOL BL = c.5 ;BACKLIGHT
SYMBOL RS = C.6
SYMBOL ENT = c.7
SYMBOL lcddata = pinsb
SYMBOL seconds = b10 ;RTC stored value
SYMBOL mins = b11 ;RTC stored value
SYMBOL hour = b12 ;RTC stored value
SYMBOL BYPASSHR = b15
setup:
BYPASSHR = 8
dirsb = 255 ;set pinsb to output
dirsc = 7 ;set pinsc
high BL ;turn on backlight
low RS ;command register
pause 100
lcddata = 1 : pulsout ENT,2 :pause 10 'Clear display
lcddata = 56 : pulsout ENT,2 :pause 10 'Function Set: 8-bit, 2 lines, font 8x5
lcddata = 12 : pulsout ENT,2 :pause 10 'Display on/off control: Display on, cursor off, blink off
lcddata = 6 : pulsout ENT,2 :pause 10 'Entry mode set: Increment, cursor shift
WELCSCREEN:
PAUSE 200 ;set PICAXE as master and DS1307 slave address
hi2csetup i2cmaster, %11010000, i2cslow, i2cbyte 'set up RTC on I2C
hi2cin 0,(b10,b11,b12) 'read RTC
pause 50
low rs 'command register
lcddata = 2 : pulsout ENT,2 'return home
pause 10
lcddata = 128 : pulsout ENT,2 'Line 1
high rs 'Data register
for b4 = 0 to 16
lookup b4,(" TANK CONTROLLER"),lcddata
pulsout ENT,2
next
lcddata = 192 : pulsout ENT,2 'Line 2
'data register
BCDTOASCII b12,b19,b20 'Change BCD to ASCII for transmission to LCD
BCDTOASCII b11,b21,b22
BCDTOASCII b10,b23,b24
high rs
for b4 = 0 to 25
lookup b4,(" TIME ",b19,b20,":",b21,b22,":",b23,b24," <-MENU"),lcddata
pulsout ENT,2
next
if pinc.0 = 1 then goto SETMENU1
goto WELCSCREEN
SETMENU1:
Pause 400
gosub SCREENCLR
for b4 = 0 to 38
lookup b4,("* SET CLOCK IRRIGATION BYPASS"),lcddata
pulsout ENT,2
next
LOW RS
pause 10
high rs
for b4 = 0 to 25
lookup b4,(" DAYLIGHT SAVING BACK"),lcddata
pulsout ENT,2
next
wait 1
if pinc.0 = 1 then goto RTCSETSCRHR 'menu screen to set clock
if pinc.1 = 1 then goto SETMENU2 'xxxx
SETMENU2:
Pause 400
gosub SCREENCLR
for b4 = 0 to 38
lookup b4,(" SET CLOCK IRRIGATION BYPASS"),lcddata
pulsout ENT,2
next
LOW RS
pause 10
high rs
for b4 = 0 to 25
lookup b4,("* DAYLIGHT SAVING BACK"),lcddata
pulsout ENT,2
next
wait 1
if pinc.0 = 1 then goto DAYSAVSET1
if pinc.2 = 1 then goto SETMENU1
if pinc.1 = 1 then goto SETMENU3
SETMENU3:
Pause 400
gosub SCREENCLR
for b4 = 0 to 38
lookup b4,(" SET CLOCK * IRRIGATION BYPASS"),lcddata
pulsout ENT,2
next
LOW RS
pause 10
high rs
for b4 = 0 to 25
pulsout ENT,2
next
wait 1
if pinc.0 = 1 then goto IRRIGOVERIDE
if pinc.2 = 1 then goto SETMENU2
if pinc.1 = 1 then goto SETMENU4
SETMENU4:
Pause 400
gosub SCREENCLR
for b4 = 0 to 38
pulsout ENT,2
next
LOW RS
pause 10
high rs
for b4 = 0 to 25
lookup b4,(" DAYLIGHT SAVING * BACK"),lcddata
pulsout ENT,2
next
wait 1
if pinc.0 = 1 then LOW RS :lcddata = 1 : pulsout ENT,2 :goto WELCSCREEN
if pinc.2 = 1 then goto SETMENU3
ENDIF
RTCSETSCRHR:
pause 400
gosub SCREENCLR
for b4 = 0 to 10
lookup b4,("* SET HOURS"),lcddata
pulsout ENT,2
next
LOW RS
pause 10
high rs
for b4 = 0 to 27
lookup b4,(" SET MINUTES <-ACCEPT"),lcddata
pulsout ENT,2
next
low rs
lcddata = 2 : pulsout ENT,2 :pause 10 'move cursor home
lcddata = 13 : pulsout ENT,2 :pause 1 'blink cursor
high RS
for b4 = 0 to 1
lookup b4,(b19,b20),lcddata : pulsout ENT,2
next
if pinc.1 = 1 then dec b12
elseif pinc.2 = 1 then inc b12
elseif pinc.0 = 1 then goto RTCSETSCRMIN
hi2cout 0,(b10,b11,b12) 'WRITE RTC
low rs
high RS
lcddata = B19 : pulsout ENT,2 :pause 1
lcddata = B20 : pulsout ENT,2 :pause 1
pause 200
RTCSETSCRMIN:
pause 400
gosub SCREENCLR
for b4 = 0 to 10
lookup b4,(" SET HOURS"),lcddata
pulsout ENT,2
next
LOW RS
pause 10
high rs
for b4 = 0 to 27
lookup b4,("* SET MINUTES <-ACCEPT"),lcddata
pulsout ENT,2
next
low rs
lcddata = 131 : pulsout ENT,2 :pause 1 'blink cursor
lcddata = 208 : pulsout ENT,2 '128 + cursor moves
high RS
for b4 = 0 to 1
lookup b4,(b21,b22),lcddata : pulsout ENT,2
next
if pinc.1 = 1 then dec b11
elseif pinc.2 = 1 then inc b11
elseif pinc.0 = 1 then goto SETMENU1
low rs
high RS
lcddata = B21 : pulsout ENT,2 :pause 1
lcddata = B22 : pulsout ENT,2 :pause 1
pause 100
DAYSAVSET1:
pause 400
gosub SCREENCLR
for b4 = 0 to 27
lookup b4,("* FORWARD 1 HOUR CANCEL"),lcddata
pulsout ENT,2
next
LOW RS
pause 10
high rs
for b4 = 0 to 27
lookup b4,(" BACK 1 HOUR <-ACCEPT"),lcddata
pulsout ENT,2
next
if pinc.0 = 1 then inc b12
goto SETMENU1
elseif pinc.1 = 1 then goto DAYSAVSET2
pause 100
DAYSAVSET2:
pause 400
gosub SCREENCLR
for b4 = 0 to 27
lookup b4,(" FORWARD 1 HOUR CANCEL"),lcddata
pulsout ENT,2
next
LOW RS
pause 10
high rs
for b4 = 0 to 27
lookup b4,("* BACK 1 HOUR <-ACCEPT"),lcddata
pulsout ENT,2
next
if pinc.0 = 1 then dec b12
goto SETMENU1
elseif pinc.2 = 1 then goto DAYSAVSET1
elseif pinc.1 = 1 then goto DAYSAVSET3
pause 100
DAYSAVSET3:
pause 400
gosub SCREENCLR
for b4 = 0 to 27
lookup b4,(" FORWARD 1 HOUR * CANCEL"),lcddata
pulsout ENT,2
next
LOW RS
pause 10
high rs
for b4 = 0 to 27
pulsout ENT,2
next
if pinc.0 = 1 then low RS :lcddata = 1 : pulsout ENT,2 :pause 10 :GOTO SETMENU1
elseif pinc.2 = 1 then GOTO DAYSAVSET2
pause 100
SCREENCLR:
low rs
lcddata = 1 : pulsout ENT,2 'Clear display
pause 10
lcddata = 2 : pulsout ENT,2 'reuturn home
PAUSE 10
lcddata = 128 : pulsout ENT,2 'line 1
pause 10
high rs
RETURN
IRRIGOVERIDE:
pause 400
gosub SCREENCLR
for b4 = 0 to 30
lookup b4,(" SET TIME :00"),lcddata
pulsout ENT,2
next
LOW RS
pause 10
high rs
for b4 = 0 to 27
lookup b4,(" FOR BYPASS <-ACCEPT"),lcddata
pulsout ENT,2
next
low RS
PAUSE 10
lcddata = 154 : pulsout ENT,2 '128 + cursor moves
PAUSE 10
BCDTOASCII b15,b19,b20
high RS
low RS
pause 200
if pinc.1 = 1 then dec b15
elseif pinc.2 = 1 then inc b15
elseif pinc.0 = 1 then lcddata = 1 : pulsout ENT,2 :pause 10 :goto SETMENU1 'Clear display:goto WELCSCREEN
