I just ran accross this problem as well so I suggest that this needs some more research.
My problem is showing up if I use the lower slider bar on my synaptics mouse/touchpad (driver 8.2.4.6 dated 3/8/06) the application encounters an error and closes. It does not happen with the up down slider.
Event viewer is telling me:
Event Type: Error
Event Source: Application Error
Event Category: None
Event ID: 1000
Date: 2/6/2008
Time: 1:59:09 PM
User: N/A
Computer: DELL_E1505
Description:
Faulting application progedit.exe, version 5.1.0.6, faulting module srcvw4.dll, version 4.0.1.0, fault address 0x00018a04.
For more information, see Help and Support Center at
http://go.microsoft.com/fwlink/events.asp.
Data:
0000: 41 70 70 6c 69 63 61 74 Applicat
0008: 69 6f 6e 20 46 61 69 6c ion Fail
0010: 75 72 65 20 20 70 72 6f ure pro
0018: 67 65 64 69 74 2e 65 78 gedit.ex
0020: 65 20 35 2e 31 2e 30 2e e 5.1.0.
0028: 36 20 69 6e 20 73 72 63 6 in src
0030: 76 77 34 2e 64 6c 6c 20 vw4.dll
0038: 34 2e 30 2e 31 2e 30 20 4.0.1.0
Now my software/hardware situation is:
OS Name Microsoft Windows XP Professional
Version 5.1.2600 Service Pack 2 Build 2600
OS Manufacturer Microsoft Corporation
System Name DELL_E1505
System Manufacturer Dell Inc.
System Model MM061
System Type X86-based PC
Processor x86 Family 6 Model 14 Stepping 8 GenuineIntel ~1830 Mhz
BIOS Version/Date Dell Inc. A12, 12/18/2006
SMBIOS Version 2.4
Windows Directory C:\WINDOWS
System Directory C:\WINDOWS\system32
Boot Device \Device\HarddiskVolume2
Locale United States
Hardware Abstraction Layer Version = "5.1.2600.2705 (xpsp.050622-1524)"
User Name DELL_E1505\Paul
Time Zone Central Standard Time
Total Physical Memory 1,024.00 MB
Available Physical Memory 287.85 MB
Total Virtual Memory 2.00 GB
Available Virtual Memory 1.96 GB
Page File Space 2.40 GB
Page File C:\pagefile.sys
Other software I have installed is Microsoft Visual Studio, Visual Basic, Visual Studio.net that might explain the Tetradyne software connection. Hardware is a Dell Inspiron E1505.
The problem I have is this error is completely reproducable therefor is obviously a problem with the editor. I'm pointing this out because you are likely to have other people over time that are going to encounter the problem and may be turned off because of it.
