Henryhens66
Hi, I'm a High school student who is doing a major work for my subject Design Technology.
Before I ask for your help I will give you a brief over view, of what product I'm designing for my major project so that any
confusions of what my questions are regarding, are clear to you.
For my design I have incorporated a pickaxe into a shelf which I have made. I have currently purchased and
assembled together a PICAXE 20M2. In that i have pursuits in using the picaxe to give life and function to my shelf as to for-fill
a design brief of purpose and need.
The Product design itself is an illuminating shelf run by LEDs, in which is controlled by a picaxe. The picaxe receives a signal from a infra-red sensor, to which is located below the shelf. So that whenever someone walks pass the shelf the infra-red sensor will pick up,and it then sends a signal to the picaxe saying ie. someone has walked pass to which it then triggers the second sensor, sandwiching the ends of platform of the shelf where you put your Important belongings ie Key,wallet,phone. The sensor sandwiching the ends of platform of the shelf allows the picaxe to know if anything is placed onto the platform of the shelf as the weight from the belongings push the platform down to hit contact with the sensor. If the sensor in-between the platform of the shelf doesn't move, after getting a signal of someone walking past the shelf from the infra-red sensor, the picaxe in the shelf will then send a signal to illuminate the red LEDs inside the shelf, to grab the attention and warn the owner who walked into the house from the front door, that they haven't placed there Key,wallet, phone onto the shelf.
The purpose of this product was to shape human behaviour to have a good habit of having your important belongings somewhere placed to be easily accessible for your Keys wallets and phone. So situations are prevented ,such as like your bus is coming in 5 mins , and that your not spending the 5 mins finding your Key,wallet and phone. Its right on the shelf in front of your door so you can take straight away and leave your house so that you don't miss your bus.
In order to fore fill the purpose of my product I have a few questions
see below-
1. First where can I find a infra-red sensor in which is compatible to send signals to my picaxe, programming wise and if so how to program?
2. If there is no infra-red sensor in which can be incorporated into my picaxe, is there any other alternatives for sensor in which can substituted for my shelf, so that it fore fills my function of my design?
3. Also if there is a infra-red sensor in which can be compatible with my picaxe, how do i program it into my picaxe? I so far know from reading the Picaxe manuals that (readadc) is to read analogue inputs into the picaxe,but im not even sure if thats right tho. so how do I program it if so?
4.Lastly if there is any suggestion of what type of sensors could be incorporate into my product design please leave the name of the type of sensor or provide a link to it.
(EDIT
Here is a picture of my product to give you a further insight of the form.
The bottom part of the picture is the side view of my shelf the top right picture is the side panels to seal of the hollow opening of my shelf and the top left picture is my picaxe 20m2 which will sit inside against the back part of the shelf in which will be supported against a wall. Also there will be LEDS inside to illuminate the shelf and sensors under the shelf etc...)
Once again thanks you very much for your time in reading this and your suggestions, I greatly appreciate if you have contributed in giving feedback to my Thread, and hope to see your reply soon.
see below-
(EDIT
