My brain is fried... a wireless network
Steve2381
Hello all
I have been playing around with a couple of ESP8266 modules. All lovely and fun. Got a local network established etc.
I am trying to basically transmit some basic data from equipment spread over a warehouse. Collect that data and send it to a webpage.
My basic webpage system appears to work, but from what I understand, you cannot have very many (apparently 8 or 10) of these Wifi ESP8266 modules configured as stations, connected (and sending data) to the ESP8266 that is your Access point.
This is a limitation (not to mention the poor Wifi range).
I am now thinking of transmitting the data to the access point ESP8266 using SI4432/RFM22B modules. I have never used them before.
I have been sitting for 2 days working on this project. I am fried. Can anyone advise on these modules? Are they reliable and have a decent range?
Thanks
I wasn't aware of that limitation - but I could believe it.
You could make them all (including the 'master'), clients of a commercial Access Point. (Or maybe the master could connect to each one of them in turn?)
Me neither ... but how about the later SI4463 modules ... that we know and love as the HC-12 :)
(https://www.appconwireless.com/shownews.php?id=95 "We suggest users choose Si4463 instead of Si4432" )
One the members here, "srnet" put a Picaxe and an RF22 on a Cubesat. It reliably transmitted data from earth orbit. I have used Si4432 modules with Picaxe. These use SPI to communicate between the microcontroller and the RF module and can be a bit tricky to configure.
The range generally depends upon the environment, antenna selection, RF power setting, and transmsision bit rate. But 200+ meters should be achievable.
There should be some code posted here that you could use to get started . If I can find it I will provide a link
https://picaxeforum.co.uk/threads/wireless-link-using-hope-rf-modules.20024/
https://picaxeforum.co.uk/threads/rssi-indicator.23521/
https://picaxeforum.co.uk/threads/g...rf4431f13-wireless-transceiver-modules.21229/
Back
