Attached is some initial work undertaken with the Dorji DRF4331F13 433 MHz wireless modules.
The hardware was supplied by forum member SAborn along with a spell check of the document
and the programming and write-up are by yours truly.
While there are many tests performed by chip and module manufacturers to determine the maximum line-of-sight range,
the testing performed here has been under my local suburban conditions with hills, cavity type double brick walled houses,
and local parklands complete with trees which are considered to represent a more "real world" test scenario.
Tests were done with a data rate of 1200 bps although the code provided is set for 4800 bps.
I did subsequent to the main write up try some settings as taken from a Dorji document which on first trial gave some
greater range - stall at 1200 bps data rate . Hopefully the time will present itself soon to undertake some further tests
with these alternative settings to see if the range improvement is consistently better. Some of the Dorji settings are
using values that do not appear within the Silicon Labs datasheet.
Note that the Silicon Labs Si4331 chip is identical to the Si4332 other than the latter has a higher power output capability.
Settings are not retained in non-volatile memory or on going into shutdown mode and must be reloaded at each power up or coming out of shutdown mode.
These Dorji modules are therefore for all intents the same as the HopRF RFM22 modules.
