Just looking for some *considered* feedback from the community...maybe be OT - maybe not if we can incorporate a PIC(axe) into it!
I have a product running from solar panels and commercial solar reg charging 12v SLA batteries (long distance modular telemetry systems)
I'm redesigning lots of the bits (from the commercial stuff to our own design) to improve power consumption and ease of *end user* install-ability!
Where I am at the moment is the solar reg - we use a *nice* STECA SSR6.6c regulator that incorporates LVD and PWM charging
http://www.steca-solar.com/en/art/uid_kategorien/0000581/id_matchcode/up_solarladeregler/id_artikel/0000037/bop/0/chksum/3a5b0dcd2606edfbe57e3a4c11fa5bdd/beetools.html
These units work great - but at a rating of 6A and a reasonably large physical size I'm looking to see if there is a better way.
Max panel size we use is 20W or an SC current of approx 1.3 amps
I wish to retain the LVD (low volts disconnect) feature to maintain reliable "reboot" of the attached radio transceiver as well as some *basic* charge level indication (like the SSR6)
Basically - is it worth going to the trouble designing out own charge controller to screw a few more mA out of (or in to!) our batteries?
Do I go the "discreet" component way, off the shelf "switcher", boost-buck controller or microcontroller PWM?
Looking around there seems to be a lot of ideas for "micropower" stuff running from "garden light" panels and stuff for 20A+ but nothing around the 1A mark which is where we are aiming for this idea.
With the size panels we are using is it even a real benefit to have all the fancy PWN charging etc - as I trying to go too far? Am i better off looking at a simple analog charge cct with low quiescent and just be happy with that (i wouldnt be happy though - not tech enough lol!)
Overall the unit will be integrated into a DIN rail mounted module that gangs side-by-side with the rest of the I/O modules (some with micros, some without - depends on module function)
One not-so-neat option is to "gut" the SSR-6 and mount it on another PCB - the actual board is HEAPS smaller than the huge box they put it in!
Cheers in advance for any ideas/feedback!
Stocky
Stocky
