In another post Goeytex said
There has been a number of instances where I have needed to use Serial communications and have servo(s) running at the same time, especially when using the PicAxe as a servo controller
It would be great if this works.. Otherwise can I add Servo and Serial do not interfere with each other to the Wish List
Dave
Can Technical confirm this - Background (Hser) serial commands do not affect the Servo?Don't give up !
It then send its data to another Picaxe that uses background serial receive that should not affect the servo command.
Dave
