I've been doing my research into robots for the Xbox 360 game, Guitar Hero. I've interfaced with controllers before, so hopefully wouldn't have any problems there, as I'd build this mod in a standard Xbox 360 controller rather than inside the guitar controller.
The only thing I'm not too sure about is storing the note lists somewhere, for the PICAXE to read them. A note list will be something like this image (http://www.bradleyzoo.com/GuitarHero/gh3-ps2/expert/slowride.blank.png) but in a format which the PICAXE can read and interpret.
There'll be at least 50 of these, so I'm assuming I need to store them externally. What options are available for external memory storage? Is it possible to save PICAXE programme subroutines on the external memory, or will I have to save the note lists as normal text which the PICAXE will parse? Will a normal PICAXE be fast enough to run through a notelist and output accordingly, or will an X2 part be required?
Once I can get the PICAXE reading a note list from some form external memory, I'll be able to handle the outputs based on this myself. I'm a decent programmer, but my electronics knowledge is limited. Do you think that this is too difficult based on my limited experience?
Looking forward to hearing responses! It's not easy to explain, so I hope you were able to follow!
