Sounds like a good episode coming up again.but you'll have to wait for that episode to arrive.
I think maybe it would be also wise to make the sleep come into play when the LDR <90 so that it is actually very dark, maybe even a lower value.
Ideally the fade in should be on the first file and the first instance of the second file, but repeating second files would sound better if a continuance of the same volume with no fading at either end, but maybe that is too hard to implement?I would have edited the main loop and added some more routines ...
It should be reasonably easy to change the main loop to do anything you want; it's just a question of choosing the right sequence.Ideally the fade in should be on the first file and the first instance of the second file, but repeating second files would sound better if a continuance of the same volume with no fading at either end, but maybe that is too hard to implement?
It is easy to prepare the files to what ever length is needed with or without fade at either end. Ideally though, files that are un-faded and controlled by the code would be a better option I think. If coding is hard to do for either type of fading, it can be done in the file itself.Fading in track one and track two is easy enough with software, as is fading out track two when dusk arrives. But fading out track one before fading in track two the first time is a little challenging.
Do
Gosub WaitForDawn
; Track 1 - Software fade-in, fade-out in track itself
Gosub SetVolumeToOff
Gosub PlayFirstTrack
Gosub FadeUpVolume
Gosub WaitForTrackToEnd
; Track 2 - Software fade-in, repeat without fading, software fade-out at dusk
Gosub PlaySecondTrackWithRepeat
Gosub FadeUpVolume
Gosub WaitForDusk
Gosub FadeDownVolume
Gosub StopTrack
Loop
; We only need to sleep for short periods during the day as
; the battery should be recharging. At night time we sleep
; for a longer period.
; Though each 'sleep' unit is about 2.3 seconds we will
; pretend it's a round 2 seconds. It might actually be one
; to four seconds but it doesn't really matter if we are a
; few minutes sooner or later in detecting dawn or dusk.
Symbol SLEEP_SECS_DURING_DAY = 2 ; Multiples of 2 and 2 minimum
Symbol SLEEP_SECS_AT_NIGHT = 8 ; Multiples of 2 and 2 minimum
Symbol SLEEP_UNITS_DURING_DAY = SLEEP_SECS_DURING_DAY / 2
Symbol SLEEP_UNITS_AT_NIGHT = SLEEP_SECS_AT_NIGHT / 2
; If we get a dawn or dusk which lasts this long we consider
; it to be a fact. Any dusk or dawn which is shorter we can
; consider a 'false dawn' or 'false dusk' and ignore that.
Symbol DAWN_PERIOD_SECS = 300 ; 300 secs = 5 minutes
Symbol DUSK_PERIOD_SECS = 300 ; 300 secs = 5 minutes
; Keep track of how long we have detected a continuous dawn
; or dusk for.
Symbol secondsCounter = w3 ; b7:b6
WaitForDawn:
secondsCounter = 0
Do
; We are waiting for dawn so can presume we are running
; at night time
Sleep SLEEP_UNITS_AT_NIGHT
Gosub ReadTheLdrLevel
If ldrLevel > LDR_LEVEL_AT_DAWN Then
; It is potentially dawn, so we count how long dawn seems
; to have lasted for
secondsCounter = secondsCounter + SLEEP_SECS_AT_NIGHT
Else
; It is not dawn so we reset the counter
secondsCounter = 0
End IF
; If it appears to actually be dawn, not a false dawn, then
; we return, otherwise keep going round the loop until it is
; dawn
Loop Until secondsCounter >= DAWN_PERIOD_SECS
Return
WaitForDusk:
secondsCounter = 0
Do
; We are waiting for dusk so can presume we are running
; during the day
Sleep SLEEP_UNITS_DURING_DAY
If ldrLevel < LDR_LEVEL_AT_DUSK Then
; It is potentially dusk, so we count how long dusk seems
secondsCounter = secondsCounter + SLEEP_SECS_DURING_DAY
Else
; It is not dusk so we reset the counter
secondsCounter = 0
End IF
; If it appears to actually be dusk, not a false dusk, then
; dusk
Loop Until secondsCounter >= DUSK_PERIOD_SECS
Return
The advantage of defining and using 'LDR_LEVEL_AT_DAWN' and 'LDR_LEVEL_AT_DUSK' is that it's easy to change those values at the top of the program while experimenting with prototype code to see what the best values are.I think maybe it would be also wise to make the sleep come into play when the LDR <90 so that it is actually very dark, maybe even a lower value.
FadeUpVolume FadeUpTrackDo Gosub WaitForDawn ; Track 1 - Software fade-in, fade-out in track itself Gosub SetVolumeToOff Gosub PlayFirstTrack Gosub FadeUpVolume Gosub WaitForTrackToEnd ; Track 2 - Software fade-in, repeat without fading, software fade-out at dusk Gosub SetVolumeToOff Gosub PlaySecondTrackWithRepeat Gosub FadeUpTrack Gosub WaitForDusk Gosub FadeDownVolume Gosub StopTrack Loop
Sorry, simple typo from typing directly into the forum. It was meant to be 'FadeUpVolume'. Corrected the original post.FadeUpVolume FadeUpTrack
Easy done, I am guilty myself of that a few times.Sorry, simple typo from typing directly into the forum
#No_Data
; Define hardware
Symbol LDR = C.7
Symbol TX = C.0
Symbol Busy_Pin = PinB.5
Symbol LDR_LEVEL_AT_DAWN = 105 ; LDR reads higher than this during the day
Symbol LDR_LEVEL_AT_DUSK = 95 ; LDR reads less than this at night
Symbol BAUD_FREQ = M8
Symbol BAUD = T9600_8
Symbol MP3_PLAY = $12 ; play track
Symbol MP3_REPEAT_PLAY = $08 ; Repeat play a track
Symbol MP3_STOP = $16 ; Stop track playing
Symbol MP3_SET_VOLUME = $06 ; Set the volume
Symbol MAX_VOLUME = $1E ; Max volume level, $1E = 30
; Variables
Symbol cmd = b0
Symbol arg = w1 ; b3:b2
Symbol arg.lsb = b2
Symbol arg.msb = b3
Symbol ldrLevel = b4
Symbol Busy_Delay = 2000 ; Change Busy delay value here
; or dusk for.
; Main program
PowerOnReset:
High TX
Do
Gosub WaitForDawn
Gosub FadeUpVolume
Gosub FadeUpVolume
Gosub WaitForDusk
Gosub StopTrack
Loop
; Day and night handling
WaitForDawn:
secondsCounter = 0
Do
; at night time
Else
secondsCounter = 0
End IF
; dawn
Return
WaitForDusk:
secondsCounter = 0
Do
; during the day
Else
secondsCounter = 0
End IF
; dusk
Return
SleepForSomeTime:
Sleep 1 ; Doesn't really matter how long we sleep for at this stage
Return
ReadTheLdrLevel:
ReadAdc LDR, ldrLevel
Return
PlayFirstTrack: ; Handle track playing
cmd = MP3_PLAY : arg = 0001 : Gosub Send ;
;gosub WaitForTrackToEnd
Return
PlaySecondTrackWithRepeat:
cmd = MP3_REPEAT_PLAY : arg = 0002 : Gosub Send ; Repeat track '/MP3/0002.mp3'
Return
StopTrack:
cmd = MP3_STOP : arg = 0 : Gosub Send ; Stop playing track
Return
; Handle volume control
SetVolumeToFull:
cmd = MP3_SET_VOLUME : arg = MAX_VOLUME : Gosub Send ; Set volume
Return
FadeDownVolume:
For arg = MAX_VOLUME To 0 Step - 1
cmd = MP3_SET_VOLUME : Gosub Send ; Set volume, 'arg' set by outer FOR-NEXT
Pause 2000
Next
Return
; Communication with DFPlayer
Send:
SetFreq BAUD_FREQ
Pause 1000
SerOut TX, BAUD, ( $7E, $FF, $06, cmd, $00, arg.msb, arg.lsb, $EF )
;gosub Check_Busy
SetFreq MDEFAULT
Return
WaitForTrackToEnd:
Do
pause Busy_Delay
if ldrLevel <95 then exit
loop while Busy_Pin=0
Return
SetVolumeToOff:
cmd = MP3_SET_VOLUME : arg = 0 : Gosub Send ; Set volume to off (zero)
Return
FadeUpVolume:
For arg = 0 To MAX_VOLUME
Pause 1000
Next
Return
; Define hardware
Symbol LDR = C.7
Symbol TX = C.0
; Variables
Symbol cmd = b0
Symbol arg.lsb = b2
Symbol arg.msb = b3
; Main program
PowerOnReset:
High TX
Do
Gosub WaitForDawn
Gosub SetVolumeToFull
Gosub WaitForDusk
Gosub StopTrack
Loop
WaitForDawn:
Do
Gosub SleepForSomeTime
Loop Until ldrLevel > LDR_LEVEL_AT_DAWN
Return
WaitForDusk:
Do
Loop Until ldrLevel < LDR_LEVEL_AT_DUSK
Return
SleepForSomeTime:
Return
ReadTheLdrLevel:
Return
Return
; WaitForTrackToEnd:
;gosub Check_Busy ; ????????????
;Return
Return
StopTrack:
Return
SetVolumeToFull:
Return
FadeDownVolume:
Pause 2000
Next
Return
Send:
SetFreq BAUD_FREQ
Pause 1000
;gosub Check_Busy
SetFreq MDEFAULT
Return
WaitForTrackToEnd:
Do
pause Busy_Delay
Return
In what way is it not functioning ?I tired is code that I have put together from Hippy's last coding and it is not functioning
#Picaxe 20M2
#No_Data
#Terminal 4800
MainLoop:
Pause 2000 ; Wait for Terminal window to be displayed
SerTxd( "MainLoop", CR, LF )
Do
Loop
WaitForDawn:
SerTxd( "WaitForDawn", CR, LF )
Return
MainLoop
WaitForDawn
SetVolumeToOff
PlayFirstTrack
FadeUpVolume
WaitForTrackToEnd
SetVolumeToOff
FadeUpVolume
WaitForDusk
FadeDownVolume
StopTrack
WaitForDawn
etc
Thanks for that Hippy, I will test it later this evening and see what happens, I can do what you have suggested to try. ThanksIf you have the board connected to the PC by the AXE027 USB cable you can add SERTXD commands at the start of each routine called from the main loop so you can see what it is doing, for example -
I put the additions into the code and tested on the computer first using the C.7 rotary slider to set the values for dawn and dusk at different times.If it shows "MainLoop"then "WaitForDawn", and nothing more, then it's stuck in the "WaitForDawn" routine, not ever exiting that.
The output looks to be what I'd expect, the "~[FF][06][06][00][00][00][EF]" are the commands the 'send' routine is sending to the DFPlayer.So have I done something wrong, misinterpreted something somewhere?
So I should give it another try and wait longer. I will put the sleep routine in again and test once or twice more.The stuff after"I set it for dusk about here " is the volume still fading up. Once it has reached maximum, '[1E]', it then enters the 'WaitForDusk' routine while still notionally playing track two.
; Written by: HIPPY
; Function: Birds calling, start at dawn play first short
; track (12 minutes) then play second track that repeats until dusk, goes
; to sleep mode to conserve battery
; Target PICAXE: 20M2 can be run on 08M2 by changing LDR,
; TX and BUSY_Pin
#Picaxe 20M2
#No_Data
#Terminal 4800
; Define hardware
Symbol LDR = C.7
Symbol TX = C.0
; Variables
Symbol cmd = b0
Symbol arg.lsb = b2
Symbol arg.msb = b3
; or dusk for.
; Main program
PowerOnReset:
;MainLoop:
High TX
Do
Gosub WaitForDawn
Gosub FadeUpVolume
Gosub FadeUpVolume
Gosub WaitForDusk
Gosub StopTrack
Loop
WaitForDawn:
secondsCounter = 0
Do
; at night time
Else
secondsCounter = 0
End IF
; dawn
Return
WaitForDusk:
SerTxd( "WaitForDusk", CR, LF )
secondsCounter = 0
Do
; during the day
Else
secondsCounter = 0
End IF
; dusk
Return
SleepForSomeTime:
SerTxd( "SleepForSomeTime", CR, LF )
Return
ReadTheLdrLevel:
Return
SerTxd( "PlayFirstTrack", CR, LF )
Return
SerTxd( "PlaySecondTrackWithRepeat", CR, LF )
Return
StopTrack:
SerTxd( "StopTrack", CR, LF )
Return
SetVolumeToFull:
SerTxd( "SetVolumeToFull", CR, LF )
Return
FadeDownVolume:
SerTxd( "FadeDownVolume", CR, LF )
Pause 2000
Next
Return
Send:
SetFreq BAUD_FREQ
Pause 1000
;gosub Check_Busy
SetFreq MDEFAULT
Return
WaitForTrackToEnd:
SerTxd( "WaitForTrackToEnd", CR, LF )
Do
pause Busy_Delay
Return
SetVolumeToOff:
SerTxd( "SetVolumeToOff", CR, LF )
Return
FadeUpVolume:
SerTxd( "FadeUpVolume", CR, LF )
Pause 1000
Next
Return
