Digital logic on noisy lines
Circuit
I need to send 8 lines of digital logic over some long wires; 20 to 100 metres perhaps, as part of a security system. PICAXEs will be at either end. The lines are in a domestic environment but may be passing a variety of other cables, mainly mains cables, washing machines and so forth, and therefore I am a little concerned about noise and inductive pickup etc.
I am reluctant to use optocouplers because the system must have a long lifetime and the optocoupler emitters would be on for 99% of the time. Optocouplers follow a decay curve and I don't really want to get into trying to calculate a lifespan and planning in the overhead necessary to compensate for decay. Therefore I am proposing to hold the interconnects at 12 volts with TBD6203APG s with 10K to 12v on each wire. Another TBD6203APG at the other end will interface back to 3.3v for the receiving PICAXE. Diagram herewith.
The TBE62083APG is a modern DMOS replacement for the ULN2803A and its characteristics seem to match these requirements better. Does this appear to be a sensible approach? Critique and expert comments or alternative suggestions would be very welcome.
(Edited to correct for embarrassingly silly mistake pointed out by Technical below.)
This won't work with open collector outputs, you have nothing here to pull the lines into a high state.
Rather than send 8-digital signals in parallel, it might make sense to combine those into serially sent bytes, using MAX3232 buffers or similar, perhaps a balanced line, to minimise any problems with noise. The sending system can package up the bits to send, the receiving system can unpack those.
If you spread the 8-bits across two bytes and add a CRC that should give good reassurance you are getting valid data.. You can send data multiple times just to make sure.
Symbol TX      = B.7
Symbol TX_BAUD = N2400
TransmitTest:
    For b0 = 0 To $FF
      Gosub SendB0
      Pause 1000
    Next
SendB0:
  ; Sends 0 0 1 1 0 0 1 1
  ;       0 1 0 1 d c b a
  ;       1 0 1 0 h g f e
  ;       1 1 x x x x x x
  b1 = b0 & $0F | $50
  b2 = b0 / $10 | $A0
  b3 = -b1 * 2 + b2 | $C0
  SerOut TX, TX_BAUD, ( $33, b1, b2, b3 )
Symbol RX      = C.0
Symbol RX_BAUD = N2400
ReceiveTest:
    Gosub ReceiveIntoB0
    SerTxd( "Got ", #bit7,#bit6,#bit5,#bit4, " "    )
    SerTxd(         #bit3,#bit2,#bit1,#bit0, CR, LF )
ReceiveIntoB0:
  SerIn RX, RX_BAUD, ( $33 ), b1, b2, b3
  If b1 < $50 Or b1 > $5F Then ReceiveIntoB0
  If b2 < $A0 Or b2 > $AF Then ReceiveIntoB0
  If b3 < $C0             Then ReceiveIntoB0
  b0 = -b1 * 2 + b2 | $C0
  If b3 <> b0             Then ReceiveIntoB0
  b0 = b1 & $0F
  b0 = b2 * $10 | b0
Edit: Changed the magic numbers
Rather than send 8-digital signals in parallel ...
Or perhaps boosted I2C with an P82B715 I2C-bus extender to an MCP23008 for 8 digital signals or MCP23017 for 16 signals. Tested by me to 50 feet over CAT5/6 cable.
If interested, I have an MCP23008 PCB design I can share.
Or perhaps I2C directly to a picaxe X2 i2c slave,
Circuit
Oh dear, I need to rethink... Well that is an embarrassing schoolboy error indeed. Okay, rather than delete my enquiry with sheer embarrassment, how about if I keep the same idea but connect the 10 K pull-ups to 12 volts+ve? And, of course, pull-ups on the receiving PICAXE pins. (Crikey, I am red-faced...) Do I now have a robust system?
Thank you for the suggestion regarding RS232, Hippy and for the code. And Ibenson for the I2C idea. I had already considered RS485 which I am using to some degree at the moment but I want simplicity, reliability and robustness. A further problem is that I cannot re-cable but must use a variety of existing cables.
I guess that I have asked half a question in that I might have more than one PICAXE running, say, some with three outputs, some with four and with more than eight inputs spread across another TBE62083APG, probably culminating in a 40X2. My question is really that I am looking at the principle only; are there any drawbacks in having such a buffer arrangement or any reason why it will not work? I am not looking at transmitting complex information; just a digital change of state and I have no shortage of pins. Furthermore, if a wire is cut then the line drops and that is detected; not so easy with RS485 nor I2c.
Ibenson, your project interests me for another item I am working on. Unfortunately, 50 feet is not adequate for my security system, but I shall study your schematic further. I have used MCP2300xx chips on I2C but never with an extender - I shall download the datasheet for the P82B715 I2C and perhaps come back to you with further questions; thank you for the images.
