No, you won't be able to do that.Another thought though, could the PICAXE power the MC14551B. Connecting the output of one of the pins directly to VDD (pin 16) of the MC14551B? Or would it need a driver?
This control would allow me to turn the joysticks on and off as well.
I'm quite sure the PICAXE could power the MC14551B (a quick read of the datasheet would confirm) but if you don't 'switch off' the joysticks at the same time you risk destroying the MC14551B.
A restriction of any semiconductor analogue switch (again stated in the datasheet) is that any input voltage to the switch must fall between its power rail voltages. If it's not powered, that's not much voltage!
