Russ, thanks but yes I am using output 7 on the 18x, you have no idea how many times I have checked that out. Latest board shows me 'blocked characters' where the welcome message should be (see pic).
When using n2400 I get the data led flashing on from off.
When using t2400 I get the data led flashing off from on.
I have tried 1200 baud rate from the 18x no difference.
I have tried 9600 baud rate on the FRM010 no difference.
One thing I read in the controller chip for the screen data sheet was
Attached is a picture of my 'vero' breadboard layout, black circles on holes indicate that the track is cut. At first the LCD looks as if it is connected incorrectly but pin 1 is connected to the link wire to ground. The LCD is on a header which makes it appear wrong.
Thanks to everyone who has assisted so far.
Regards.
Lez.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Sorry about the size of the picture but I thought that bigger was better in this case, ( technique is rumoured to be a good start too !!!) so I'm told, often!
This is on p33 of the datasheet here, I don't know if this is 'standard' procedure for 4 bit control.· Interfacing to a 4-bit MPU
The HD44780U can be connected to the I/O port of a 4-bit MPU. If the I/O port has enough bits, 8-bit
data can be transferred. Otherwise, one data transfer must be made in two operations for 4-bit data. In
this case, the timing sequence becomes somewhat complex. (See Figure 17.)
See Figure 18 for an interface example to the HMCS4019R.
Note that two cycles are needed for the busy flag check as well as for the data transfer. The 4-bit
operation is selected by the program.
Regards.
Lez.
