@Pfrogs,
didn't know you could do that with the serout lines for the LCD, thanks for that, you could have achieved far more than you realise, I had run out of code space in my 18x and had to slim it down a bit. I can now possibly add back the things I wanted to put in.
The backlight will be driven through a pair of parallel channels in a ULN2803A darlington.
Thanks for the advise, it's appreciated.
Regards.
Lez.
@beaniebots,
I am replacing the whole AXE033 with a FRM010 and the new LCD. My code for the AXE033 used
n2400, am I using the wrong commands?
@drjeseuss,
I have not explained fully and I apologise for that, please see above. All jumpers on the FRM010 are set to open, which should be :
Welcome message
on
Baud rate
2400
Serial protocol
not inverted
Line configuration set to
2 lines
I beleive that this is right.
Regards.
Lez.
Went back and checked the Serout command, am I right in saying that as I am using the serout7, n2400 command,
Pin specifies the output pin to be used. Baud mode specifies the baud rate and
polarity of the signal. When using simple resistor interface, use N (inverted)
signals. When using a MAX232 type interface use T (true) signals. The protocol is
fixed at N,8,1 (no parity, 8 data bits, 1 stop bit).
I am doing this correctly?
Regards.
Lez.
