Attached is a schematic of my chicken coop door opener. I am reasonably satisfied with the circuit, and have built and tested a prototype.
I have also written some very rudimentary PICAXE code. While it is functional with the hardware, it is very basic, and I would appreciate constructive criticism.
Thanks.
Thanks.
init:
b1 = 0
readadc 4, b1 'read value on pin 4 into variable b1
if b1>150 and PinC.3=1 then 'if b1 is greater than 150, and SW1 is (normally) closed, then open door
goto open
if b1<150 and PinC.2=1 then 'if b1 is less than 150, and SW2 is (normally) closed, then close door
goto close
goto motoroff 'if neither set of conditions is met, turn motor off
open:
low 0 'disable clockwise rotation
high 1 'turn motor counter-clockwise
close:
low 1 'disable counter-clockwise rotation
high 0 'turn motor clockwise
motoroff: 'disable all motor rotation
low 0
low 1
