biggmacattack
I'm another xbox controller modder and wanted to thank everyone who worked with castlecrazy on his project. It was a huge help in getting mine done.
At this point I have succesfully gotten my -08m to operate two buttons at the speed I wanted them to. The code I have cobbled together (from other peoples posts and hard work) seems to be working fine but I wanted to post it up in case anyone see's some way to make it run even smoother.
At this point I have taken it as far as I can go with the knowledge I have and will happily accept any constructive criticism.
But mainly I really wanted to say thanks to everyone who worked to help the other xbox modders get their projects done, it helped me a lot. I also have 3 extra -08M's that I'm looking forward to doing other projects with. ( I bought 4 with the thought that I would probably at least destroy 2 or 3 in the process)
I'm using a -08M and this program represents two additional button added to a video game controller that will override the original buttons and allow the controller to simulate rapid button pushes.
Leg 1 represents the output to button "A"
Leg 2 represents the output to button "B"
Pin 4 represents extra rapid button "A"
Pin 3 represents extra rapid button "B"
Extra button "A" is allowed interuppt the leg2on sub with and logic
Main:
Setfreq m8
If pin4 = 1 then gosub Leg1on
If pin3 = 1 then gosub Leg2on
If pin4 = 0 then gosub leg1off
If pin3 = 0 then gosub leg2off
Leg2on:
high 2
Pause 23
low 2
pause 15
If Pin3 = 1 and pin4 = 1 then leg1on
If pin3 = 0 then exit
loop while pin3 = 1
Leg2off: b0=b0 and %00000000' bit 2 input
Let dirs=B0
Leg1on: do
pulsout 1, 250
b0=b0 and %00000010' bit 1 output
Let dirs=B0
If pin4 = 0 then exit
loop while pin4 = 1
Leg1off: b0=b0 and %00000000' bit 1 input
Let dirs=B0
