I've just ordered the parts to build this circuit, which is basically a wireless control system with a security mechanism.
This is my first schematic slash original circuit design. I'm not very used to electronics so any help with this circuit would be great. I still don't fully understand how resistors work, and chose the values based on what i've seen others using.
The main components are an XBee-PRO wireless module, (2x) Picaxe 18X microprocessors, and (2x) MCP23017 I/O expanders. The entire circuit runs on 3.3v.
The main Picaxe 18X is connected to the XBee-PRO wireless module to communicate with other control boxes. It is also interfaced with two MCP23017 I/O expanders, providing a total of 32 inputs and outputs which are in turn connected to 16 input NO momentary push buttons and 16 output LEDs.
The security part of the system has its own Picaxe 18X connected to a 12-digit keypad, along with two input NO momentary push buttons and two output LEDs. It has a one way connection to the main Picaxe 18X which it uses to enable and disable the entire system.
Any suggestions/corrections? Cheers guys!!
http://www.getbweb.com/stuff/controlsch.gif
