John Chris
Hi there,
I'm using the 28X1 to communicate with the Vinculum VDIP1 using the hardware serial pins. A command such as this,
'HSEROUT 0,("WRF ",$00,$00,$00,$08,CR,"AAAAAAA",CR)
that I found in an archived post does what one would want - that is, write chars to an open file. In this case it writes seven 'A' characters and a new line. This works.
I don't understand, however, why the three $00 are necessary? I accept it, just don't understand it.
Might someone dissect the above command and explain what is happening?
For reference, the firmware users manual is called: 'UM_VinculumFirmware_V205.pdf' and is easily found (a little too large to post)
Thanks
Thanks
