bfgstew
Good morning all.
I have been making inroads into using the parallel OLED interface kindly submitted by Nick12ab, I have it up and running and is as sweet as a nut, rapidly fast and am very impressed with its performance.
BUT, and with all things, there is a trade off, parallel is code hungry, very hungry compared to serial. It is also, for us newbees, fairly complicated to code compared to serial, and this is my hurdle to get over. Now Nick has given a great tutorial on how to impliment the OLED and have read it and understand most of it, and am very greatful to Nick for taking his time to show it. However, I am attemting to write a word variable to give a time as each key is pressed I would like the screen updated to show the value in w?. I have it sort of working but the values are, it seems, a digit over what I want, if I put in 2222, I get 22222 back, 0022 I get 002222. To put a word variable into bintoascii you need 5 byte variables, as I only need to go up to 9999, therefore only need 4 byte variables, is this the problem
The keypad is a 4x3 matrix that is proven to work and is working perfectly.
OLED is driven, parallel, via 40X2 off pinsB and C.7 and C.6. as per documentation and works.
This is how I used to get a value into a word variable with serial interface.
Keypad scan routine is the same for both.
This is what I am running at the moment on the parallel interface to input into w?
Any pointers would be greatfully received, many thanks .
Stewart
For b55 = 1 to 4
Gosub GKP
if key_value = 12 then return
pause 30
w1 = w1 * 10 + b1
serout B.7,N2400,(254,203,"D1-",254,206,#w1,"ms")
pause 30
next b55
Return
GKP:
Do
Gosub GTKP ' Wait until no key pressed
Loop Until key_value = 0
Do
Gosub GTKP ' Wait until key pressed
Loop Until key_value <> 0
If key_value = 11 Then
key_value = 0
End If
Return
GTKP: ;Keypad scan coding
key_pos = 0
key_value = 0
High ROW1 : gosub ScanCol : low ROW1
High ROW2 : gosub ScanCol : low ROW2
High ROW3 : gosub ScanCol : low ROW3
High ROW4 : gosub ScanCol : low ROW4
Return
ScanCol:
if COL1 = 1 then : key_value = key_pos + 1 : endif
if COL2 = 1 then : key_value = key_pos + 2 : endif
if COL3 = 1 then : key_value = key_pos + 3 : endif
key_pos = key_pos + 3
drop1:
dirsB = 255
low rs
output enable
lcddata = %00111011 : pulsout enable,16
lcddata = %00000001 : pulsout enable,608
lcddata = %00001100 : pulsout enable,608
lcddata = %00000110 : pulsout enable,16
low rs
lcddata = 128 : pulsout enable,1
high rs
for loopcounter = 0 to 20
lookup loopcounter,(" DROP ONE: ____ms "), lcddata
pulsout enable,1
next loopcounter
For b21 = 0 to 3
low rs
lcddata = 139 : pulsout enable,1
high rs
Gosub GKP
if key_value = 10 then goto initd1
w2 = w2 * 10 + b1
for loopcounter = 0 to 4
BinToAscii w2,b50,b51,b52,b53,b54
lookup loopcounter,(" ",b51,b52,b53,b54), lcddata
pulsout enable,1
next loopcounter
next b21
pause 2000
Return
Stewart
