Have to agree with you on that point. You'll never find me queuing for 72 hours outside an Apple store for the latest iPhone 27. Nor, for that matter, will I buy a newly released model of car. As for replacing Windows 10 - I still have to run Windows XP under Oracle's VirtualBox for one application that I have.Well, I'll likely run Win 10 for as long as it continues to work......
Zero, fortunately. I also saw several mentions of implanted malware online, so I first logged with a burner Outlook account so I could scan for malware. Norton, Malwarebytes, SuperAntiSpyware and Defender, all found nothing.Have you determined how much malware was pre-installed on the LarkBox? There seems to be a rash of that going on in the small computer boxes.
They forgot the GPIOs!
and "real" Serial Ports...... If you want to be compatible with older technology.....
I have a Velleman K8048 PIC programmer .... only works on a "real" RS232 serial port.. (uses pins 3,4,5 and 7,8,9 no pin 2) ...... won't work on a USB to Serial adaptor.....not even Rev Eds....
Hi erco..... "How do you paste in the wee link type quote "piclt said" etc.....??
You said..... " My main desktop at work has a real serial port"...... Yes, because it was probably asked for when buying.....
OK found it, it gives a reply quoting the whole of the text....... also discovered if drag across to highlight a part line of text and then click the popup reply..... you get a reply quote with only the text highlightedClick "Reply" (next to "Like")
I also have a 2013 HP desktop. I upgraded the HD to a SSHD, and since the internal WiFi and network adapter, which is integrated on the motherboard went kaput, I attached an USB Wifi adapter.I'm with kfjl - you use the hardware until you've squeezed the last CPU cycle from it ;-) The Dell E6420 I'm using now is from 2013. Dell does NOT support running Win 10 on it but it works just fine! The $100 delivered laptop also works acceptably fast with an after-market SSD. That means I have a few $$ to spend on PICAXE chips and peripherals ;-)
