luminastrum
The "Getting Started" datasheet iilustrates that pin #1 on the 28X1 should be tied to +5V with a "4k7" ohm resistor. Does that mean 4.7K or 47K? Thanks.
No-one has yet asked how big a switch and how heavy the traces, so I will....Having the resistor to +5 means you can have a reset switch that grounds the pin and does a reset. You can do it with the pin tied directly to +5, but you need a big switch and heavy traces on the PC board ;-)
John
It dosn't matter how big or small things are it's still called a short circuit.No-one has yet asked how big a switch and how heavy the traces, so I will....
