plasmaninjaa
All I need to do is control the direction that a DC motor is spinning.
Every time I hook it up, there is ZERO response from the motor and the darlington transistors heat up to the point of smoking.
I have checked my wiring a million times but no luck.
See the attached pictures.
The two transistors closest to the motor are the tip122
the other two transistors are the tip127
the power is a 12v battery with a 5v regulator for the picaxe.
This is the schematic I was following: http://static.electro-tech-online.com/imgcache/3422-hbridge4IO.png
I have also tried this schematic with no luck: http://www.talkingelectronics.com/projects/200TrCcts/images101-200/H-Bridge-4.gif
my code for now is to just make the motor change direction every second
high b.5
high c.1
low b.4
low c.0
low b.5
low c.1
high b.4
high c.0
I am not sure whether I should be turning on pin b.5+c.1 and b.4+c.0 on at the same time or vice versa, however I have tried both and neither work.
I am at a loss as to what I am doing wrong. Solutions would be greatly appreciated!
high b.5
high c.1
low b.4
low c.0
low b.5
low c.1
high b.4
high c.0
