Was all working fine, in use in its intended application, then on the next power up (no software changes made) I get some vertical lines on both rows, with different intensity "pixels" on them
If i have characters to display in those positions I seem to get "additive" results on the matching pixels
Rock steady 5v supply, decoupling caps etc all in place...it was all working fine then, honest, nothing changed at all except switch on/off and then those lines appeared.
It was being used outside periodically during the day, and it had got a bit warmer in the afternoon - but to no more than 25C (not in the UK!), Today, in the house (in the UK) it's 16C and the lines are still there
(by the way, am using the OLED "bare", ie without the onboard PICAXE, and using an 8 bit interface)
