I see they can work down to 1.8 volts, but does this mean they have a max supply voltage of 3.3 like the other low voltage parts, or can they work from a 5 volt supply still?
Low Voltage Operation
The M2 parts have an internal 3.3V silicon die, but also contain an internal Low Drop Out Regulator, which is
automatically enabled when required. This means all M2 parts can be used across the entire 1.8 to 5V voltage
range. Input/Output interfacing can be at 3.3V or 5V. Powering from 2xAA cells rather than 3xAA cells is now fully
supported. Brownout voltage (if not disabled) is 1.9V.
