What is meant by "Min Res"?
KMoffett
Unless you are having your PBCs "machine stuffed", why would you buy 0Ω resistors over a bent pieces of #22 wire?
Ken
SilentScreamer
It's for my GCSE project, looks far better to not have badly bent pieces of wire lying around though it probably doesn't make any difference id still rather.
EDIT: I can't buy online else id get them from rapid.
The Maplin "min res" series is simply "Miniature Resistors".
They're actually 'standard' 1/4W ones. (but smaller than the old 1/2W ones)
As to whether 1R is neglidgeable, that depends on your circuit.
If it's in a power line, then no.
If it's between a PICAXE O/P and I/P, then yes.
kevrus
Although a bent piece of wire does the job admirably, I also prefer to use the 0 ohm links (resistors) as I think they look better. I got mine from REV-ED in a pack of 100.
Wire jumpers / links for PCB's
... looks far better to not have badly bent pieces of wire lying around ....
QUOTE]
I agree with KMoffatt.
I often use the excess lead from actual resistors for 1 hole (2.5mm) and 2 hole (5mm) links.
I use a pair of needle nose pliers for neat bending. For a 1 hole jumper shap it around the tip of the pliers and for 2 hole shape it around the rear of the needle nose section.
