Hello, yup I have programmed an 18M2 already but I mean with regards to chips that do not fit on the T4 boardThe T4 Trainer has a programming socket on-board so you can program your PICAXE in situ on the T4. All you need is a suitable download cable.
Cheers for the info. I will take a look. No worries I will programme other chips via a bread board, was just curious, never thought of power pins being different and the like.If you have a look at the PICAXE pinouts
Here:http://www.picaxe.com/What-is-PICAXE/PICAXE-Pinouts/
Or in the PICAXE manual1 around page 9 onwards
You will see that not only are the SerialIn/SerialOUT pins at different locations compared with othe M2 parts but also the power pins are at different locations.
Therefore even if you programmed a different M2 part on say a breadboard, you could not plug it into the T4 board and have it work.
I am not familiar with a ZIF socket, forgive my ignorance but can I plug my axe027 cable into that or does the ZIF go on a bread board?I only tend to use 08M2's, 14M2's & 20M2's for my project work.
They can all be programmed in the same 20 pin ZIF socket.
(have used a few 18M2's for serial LCD & OLED displays though).
Neil.
Or, for a little more cash,For the small 08M2 boards, just get one of these Picaxe project boards:
http://www.picaxe.com/Hardware/Project-Boards/PICAXE-08-Proto-Board/
I have used several of these in projects, they are very small so they fit into lots of enclosures, and it's surprising what you can do with an 8-pin chip and a little ingenuity.
http://www.picaxe.com/docs/axe055.pdfI have a Picaxe T4 training board with a 18M2 chip.
Thanks for the pdf!lets try to keep in mind that the OP (Ceemag) is new to this forum, new to PICAXE and at post 1 stated:
