...that Rev Ed would consider changing the infrain2 command so that it will accept IR codes from non-TV device codes?
The reason I ask is because I'm working on a project where I'd like to use infrain2 to capture Sony IR Remote codes for a Sony A/V receiver (amplifier) rather than a Sony TV.
Ideally, it would be nice if you could pass infrain2 a value which corresponds to the device ID that you want to receive. For backward compatibility, make the device ID argument optional, so if you don't supply one it, it will continue to work exactly as it does now.
