How accurate is the vsm timing?
im trying to see if its plausable to use a pic to do analogue sampling at 30hz with quite a bit of other processing going on.
hippy (or another senior member) said that the adc sample time was 250 us, which suggests a possible speed of 4khz.
however, just sampling and toggling a pin will only simulate at 100hz. which is correct?
also changing the clock speed in the pacaxe's properties doesnt seem to change this.
