B BruceABT New Member Oct 9, 2012 #1 Has anybody noticed that the Reset pin doesn't simulate In my running simulation, nothing happens when the wired reset switch is pushed/actuated. I should think this also applies to >18 pin Picaxe chips, although have not tried them yet. Bruce.
S SD70M Senior Member Oct 9, 2012 #2 According to the Picaxe manual 1, page 10, there's no reset pin on the 18M2, but there was/is on the 18M older picaxe. Not sure how relevant that is though. Angie
Technical Technical Support Staff member Oct 9, 2012 #3 As stated above, there is no reset pin on an 18M2.
S SD70M Senior Member Oct 10, 2012 #4 Bruce, You can use any of the input pins as a reset pin by adding code within your program as long as you check for it on a regular basis. Angie
