Has anyone out there tried Hippy's diode mixing on VSM using 14M's.
I have a Master 14M polling two Slave 14Ms on one comms line with an acknowledgment being returned via a separate comms line. All works fine with each Slave connected to the return bus individually but when I connect the Slave outputs together using Hippy's configuration VSM responds with "Inputs on Master Input left floating".
I've tried all and sundry to no avail and can only suspect it may be VSM - HELP Please.
Hooter
Hooter
