buntay
Hello again all,
Hopefully this question can be answered simply.
I have been commissioned to retro fit a piece of equipment for my place of work due to the fact that the electronics and PLC are so out of date that the company doesnt even have the program for one even if we found a plc.
Here is the question.
the whole system uses a 24v,dc parts, I know 24v will blow out an input or maybe the whole chip.
I thought about using voltage dividers but wouldnt it just be simpler to use something like a 78L05 regulator?
do these regulators force 100Ma or will picaxe just take what it needs? Response time isnt critical but voltage spiking would not be desirable. They would be used on a proximity sensors that sends out 24v,dc.
also what would be the best way to do the outputs? Again, i need to go from 5v to 24. I thought about relay boards from ebay. Is there an easier way?
I would ideally like to encapsulate everything and just have a 25 pin D-sub connector to the terminal strip due to washdown conditions. They would like 5 PLC's, 1 and 4 backups ( i guess they figure that by the time those would be used up they will get rid of it for scrap) I have to pay for the prototype (will be re-embersed if it works) and then they will pay for all the parts for the other 4 so I need cheap, yet reliable electronics. Any ideas on how to make sure the system never sees 24v where its not supposed to would also be deeply appreciated.
Thanks all,
F
Thanks all,
F
