I have a PICAXE-08 board which I have built with standard components apart from R2 where I have substituted the 22K resistor with a 33K resister as I damaged the 22K one (pulled a leg off).
The flowing is done on an empty board, program cable removed, jumper in PROG position. The chip is a brand new 08M, and pin 1 is aligned with arrow.
When I connect to a battery (new AA's) and measured the voltage, I get 4.52V, connect to board and I get 0.1V, unplugged and checked battery, still 4.52V. I try a 100uF capacitor and reconnect, 0.45V, and when disconnect 4.52V. The current is less than 1mA, and settled down about 72uA.
The resistance between + and - is Millions of ohms. I have checked the circuit and all looks fine.
Can anyone suggest anything?
