I know that already exist many posts about Voltage monitor... but after reading all the posts I’m still have doubts
My rechargeable battery has 3,7v and because of some ICs I will use a 3,3v voltage regulator supplying my 20x2 Picaxe and all the others ICs.
I want to monitor the battery’s voltage (to alarm in low battery).
My internal Vref+ will be 3,3v (Picaxe’s Vcc)
What will be my ADC readings «readadc10» (if I connect to ADC3 the battery’s voltage) when battery is fully charged with 4,2v (since the Vref+ will be 3,3v)?
(note: because this is a rechargeable battery the voltage will change from 4,2v to 3,2v and I want to alarm when the voltage drops to 3,6v)
Thank you
Thank you
