I have trying out a voltage divider setup on a breadboard, and have it working correctly, but I am unsure of the values for the resistors needed to get a good spread of values for the analogue reading.
At the moment the plan is for two lots 6 identical resistor values going to two analogue pins to make up 12 different readings or 12 on one pin, but my experiment with 1.5K resistors had values like - 254, 15, 8. As you can see not what I want, can someone give me an idea on what size resistors to try, and is the pull down resistor value critical?
