Vmusic2 cockrill
Rampz
Well-known member
Or of course you could create a simple PICaxe lookup table to relate a volume control level to each track.
Thank you Alan, I have read several examples of tables but can't get my head around how to implement it in my code? I would say increasing the volume by an amount of steps above the volume set is the best way for what I'm doing. My master volume if you like is written to eeprom I wouldn't want each table change to get written to eeprom too, just changes as they do at the moment.
#picaxe 14m2
#no_data
#terminal 4800
Symbol TX = B.4
Symbol RX = C.3
Symbol BUSY_PIN = pinC.2
Symbol BAUD_FREQ = M8
Symbol BAUD = T9600_8
Symbol cmd = b0
Symbol arg = w1 ; b3:b2
Symbol arg.lsb = b2
Symbol arg.msb = b3
Symbol varA = w2
symbol varB = w3
Symbol BTN = PinB.5 'volume up
Symbol BTN1 = PinB.3 'volume down
Symbol BTN2 = PinB.2 'next song
Symbol AXE134pin = C.1 'connected to screen input
Symbol Pressed = 1
init:
High TX ; set TX pin high for idle high serial
SerTxd("Get ready to Rock", CR, LF )
Pause 3000
'varB = 8 'initial volume setting
'cmd = 0x06 : arg = varB : Gosub Send
'SerTxd("init volume set to ", #varB, CR, LF ) ' added to display its value at this time
'pause 2000 ' added pause to see if it helped
read 0,WORD varB 'added to read previous volume from eeprom position 0
'SerTxd("eeprom volume set to ", #varB, CR, LF )
         SEROUT AXE134pin , N2400_4 , ( 254 , 128 ); Position the cursor (at start of top line)128 top line
             SEROUT AXE134pin , N2400_4 , ( "Programming by Rampz")     ; Send to AXE134
SerTxd("Selected USB", CR, LF )
cmd = $09 : arg = $0001 : Gosub Send '0001 for usb, 0002 for sd card
pause 4000
cmd = 0x07 : arg = 0002 : Gosub Send ' EQ rock
SerTxd("Equlizer set to rock", CR, LF )
         SEROUT AXE134pin , N2400_4 , ( 254 , 192 ); Position the cursor (at start of top line)128 top line
             SEROUT AXE134pin , N2400_4 , ( "Equ to Rock, Set USB")     ; Send to AXE134
cmd = 0x06 : arg = varB : Gosub Send   'Volume set at 8 of 30, altered to read varB
    SerTxd("volume set to ", #varB, CR, LF ) 'display volume setting from eeprom hopefully
      SEROUT AXE134pin , N2400_4 , ( 254 , 154 ); Position the cursor (at start of top line)128 top line
        SEROUT AXE134pin , N2400_4 , ( "Volume=" , #VarB ," " )     ; Send to AXE134
Pause 1000
Gosub playsong
playsong:
    For varA = 1 To 114
    SerTxd("Playing song 000", #varA, CR, LF )
      SEROUT AXE134pin , N2400_4 , ( 254 , 215 ); Position the cursor (at start of top line)128 top line
        SEROUT AXE134pin , N2400_4 , ( "Playing Song " , #VarA ,"  " )     ; Send to AXE134
    cmd = $12 : arg = varA : Gosub Send
    Pause 1000
    Do While BUSY_PIN = 0
    Pause 100
    IF BTN = Pressed then
    pause 50
    Gosub volumeup
    IF BTN1 = Pressed then
    pause 50
    Gosub volumedown
    IF BTN2 = Pressed then
    pause 50
    Gosub playnext
    Loop
    next
    Pause 1000
do: Gosub playsong: loop 'altered was (return)
Send:
SetFreq BAUD_FREQ
Pause 10
SerOut TX, BAUD, ( $7E, $FF, $06, cmd, $00, arg.msb, arg.lsb, $EF )
SetFreq MDEFAULT
Return
volumeup:
       varB = VarB + 1 max 30
       write 0,WORD varB 'write value to eeprom positiom 0
          SEROUT AXE134pin , N2400_4 , ( 254 , 154 ) ; Position the cursor (at start of top line)128 top line
       SerTxd("volume ", #varB, CR, LF )
       cmd = $04 : arg = $0000 : Gosub Send
Volumedown:
        varB = VarB min 1 - 1
        write 0,WORD varB 'write value to eeprom position 0
        cmd = $05 : arg = $0000 : Gosub Send
playnext:
       varA = varA + 1
       cmd = $01 : arg = $0000 : Gosub Send
       pause 500 ;;;;; added to stop double song issue, but slowed skipping song down
'cmd = 0x08 : arg = 0001 : Gosub Send 'repeatably play song 0001
'cmd = $12 : arg = 0001 : Gosub Send 'play song 0001
Jeff Haas
Try this one:
It's open source software that will normalize the volume of all your MP3s. It's much easier to fix it this way than trying to tweak the playback.
AllyCat
Yes, IMHO normalising the MP3s is a much better solution, but anyway the varA and varB could/should be renamed, e.g. track and vol respectively and set as byte variables (if they're not byte values, then there are other issues to consider).
I don't know how you would plan to measure (other than as above) the amount of gain change required, but in principle the "lookup" for the gain (change) could be of the form : READ track , volchange , or maybe for the 14M2 and above : READTABLE track , volchange . Then new variables can be used for : setvol = vol + volchange MAX 30 , etc..
tmfkam
Try this one:
That's what I used on my Mac, and on Windows now. If it is set to change the file volume (as opposed to just including a "note" in the file headers) the volume stays consistent across multiple devices and operating systems.
tmfkam
The MP3 file format is quite complex so you probably need to use an "App" of some kind. The most common "free" software is "Audacity", but I haven't used it much myself, and couldn't see an "Automatic Gain Control" mode as such. Personally, I've used a freeware program called "MP3DirectCut" for many, many (20+) years which does have an option to : Edit > Normalise , that quickly sets the peak amplitude to just below clipping (or any other value you select). Only for MP3 files and I recall it may need a few other software resources to be installed, but IMHO worth a try if you find Audacity too overwhelming.
Audacity does have a normalise function - possibly called Amplify - a target db level can be set, something like 89db is what I aim for. The advantage of mp3Gain is that it can be batch controlled to process entire folders of music, setting them all to a target volume level, up or down. I never figured out how to do that with Audacity.
Rampz
Well-known member
Thank you Everyone
MP3Gain seems to do the job, i have converted all my tracks and will try later
One other issue, i'm thinking, in my code i specify the number of tracks as below
playsong:
    For Track = 1 To 114
    SerTxd("Playing song 000", #Track, CR, LF )
Is there a better way to arrive at the number of tracks in the file, currently i will have to alter my code each time i think, i see from the data sheet for the DFplayer mini that it has a command that reads the number of tracks? Could this data then be used instead of my coded number?
Edit
I can see from the DFplayer Mini pdf that under section 2 ref Query the system parameters, 0x47 Query the total number of USB files, i think i need to use SERIN? Will i need say a "Gosub receive"?
Symbol RX = C.3
Symbol TrackNum = w4
serin RX,N2400,( $7E, $FF, $06, $47, $00, $00, $00, $FE, $B4, $EF ) 'not going well here, trying to i guess send a command and get a
        responce and write it into Tracknum as a number
serin RX,N2400, #TrackNum
playsong:
    For Track = 1 To TrackNum
    SerTxd("number of files ", #TrackNum, CR, LF ) 'added to read quantity of files
Edit
Thank you Alan i have altered my symbols to make them easier to understand, i seems to have sorted the Volume to read and write to eeprom as a byte rather than a word
Rampz
Well-known member
Ok so i have tried to set up a "receive" for receiving quantity of tracks from USB, i added some code from a Hippy from a post by 1968neil and the below now reads the number of tracks correctly and appears to work, can anyone see any issues?
#picaxe 14m2
#no_data
#terminal 4800
Symbol TX = B.4
Symbol RX = C.3
Symbol cmd = b0
Symbol arg.lsb = b2
Symbol arg.msb = b3
Symbol Track = w2
symbol Vol = b6
Symbol Pressed = 1
symbol TrackNum = W4
init:
Pause 3000
read 0, Vol 'added to read previous volume from eeprom position 0
pause 2000
cmd = $47
Gosub Receive
SerTxd( "trackNum=", #arg, CR, LF )
cmd = 0x07 : arg = $0002 : Gosub Send ' EQ rock
    cmd = 0x06 : arg = Vol : Gosub Send   'Volume set at 8 of 30, altered to read Vol
    SerTxd("volume set to ", #Vol, CR, LF ) 'display volume setting from eeprom hopefully
        SEROUT AXE134pin , N2400_4 , ( "Volume=" , #Vol ," " )     ; Send to AXE134
Pause 1000
Gosub playsong
playsong:
        SEROUT AXE134pin , N2400_4 , ( "Playing Song " , #Track ,"  " )     ; Send to AXE134
    cmd = $12 : arg = Track : Gosub Send
    Pause 1000
    Pause 100
    pause 50
    Gosub volumeup
    pause 50
    Gosub volumedown
    pause 50
    Gosub playnext
    Loop
    next
    Pause 1000
Send:
SetFreq BAUD_FREQ
Pause 10
SetFreq MDEFAULT
Return
Receive:
SetFreq BAUD_FREQ
  Pause 10
  SerIn  RX, BAUD,   arg, arg, arg, arg, arg, arg.msb, arg.lsb
  SetFreq MDEFAULT
  Return
volumeup:
       vol = Vol + 1 max 30
       write 0, vol 'write value to eeprom positiom 0
       SerTxd("volume ", #vol, CR, LF )
Volumedown:
        vol = Vol min 1 - 1
        write 0, vol 'write value to eeprom position 0
playnext:
       Track = Track + 1
Another issue i just noticed, more of a question, i didn't really feel i could notice any different regards the Equalizer, just noticed i have possibly missed "$" from infront of the arg = 0002 below, would that mean that previously it will have just not worked?
tmfkam
Firstly, after you've printed out the number of tracks you've got an "End" statement so I guess it stops there?
The number of tracks returned *can* include non-music tracks and possibly folders too. I always use this as a best guess. It is normally spot on, but I don't rely on it. If you don't have any non-mp3 files on the disk you may not find this an issue.
I get the number of tracks from the player, then if I attempt to play a track that doesn't load set the value of maximum tracks to be reduced to one less than the track I tried to play.
I also found that I didn't need to initialise the USB disk if no uSD card was fitted. If there was a uSD card and a USB disk attached I would sometimes struggle to get the USB disk to start. With only one present, I had no such problems.
Might the equaliser only work on the headphone (line out)? It isn't something I ever used.
Rampz
Well-known member
Thank You tmfkam
I did notice that "end" and removed it, that seemed to run after that, but if i do a download of code in the terminal it shows 114 which is the correct number of songs, but if i cycle the power as say recovery from power cut it shows count as 1 for some reason, then as i play other songs i want the oled to show playing say 1 of 114 on this occasion, but that part isn't working, it just displays 1 both on oled and terminal.
I will have a play with removing the "set to usb" part and see what it does, doesn't seem to matter either with or without
Still some issues but basically getting towards a useable setup
Edit
I used this code from hippy altered to suit my Gosub name etc, wondering how the info received from Serin command knows to end up in TrackNum which is W4, i used a word incase i have more than 255 tracks, i have replaced "arg.lsb" with "TrackNum" and it appears to work
cmd = $47
Gosub Receive
SerTxd( "TrackNum", #arg, CR, LF )
Receive:
  SetFreq BAUD_FREQ
  Pause 10
  SetFreq MDEFAULT
  Return
Current Code
#picaxe 14m2
#no_data
#terminal 4800
Symbol TX = B.4
Symbol RX = C.3
Symbol cmd = b0
Symbol arg.lsb = b2
Symbol arg.msb = b3
Symbol Track = w2
symbol Vol = b6
Symbol Pressed = 1
init:
Pause 3000
'cmd = $09 : arg = $0001 : Gosub Send '0001 for usb, 0002 for sd card
'pause 3000
cmd = $47
Gosub Receive
SerTxd( "TrackNum ", #TrackNum, CR, LF )
pause 2000
Pause 1000
Gosub playsong
playsong:
      SEROUT AXE134pin , N2400_4 , ( 254 , 212 ); Position the cursor (at start of top line)128 top line
SEROUT AXE134pin , N2400_4 , ( "Play Song " , #Track ," ", "of ", #TrackNum ," " )     ; Send to AXE134
    Pause 1000
    Pause 100
    pause 50
    Gosub volumeup
    pause 50
    Gosub volumedown
    pause 50
    Gosub playnext
    Loop
    next
    Pause 1000
Send:
SetFreq BAUD_FREQ
Pause 10
SetFreq MDEFAULT
Return
Receive:
SetFreq BAUD_FREQ
  Pause 10
  SerIn  RX, BAUD,   arg, arg, arg, arg, arg, arg, TrackNum
  SetFreq MDEFAULT
  Return
volumeup:
Volumedown:
        vol = Vol min 1 - 1
playnext:
       Track = Track + 1
       SerTxd("Playing song 000", #Track," of ", #TrackNum, CR, LF )
when i cycle power it still returns showing playing 1 of 1 even though it will still count upwards eg 1 of 2, 1 of 3, but returns fine when i do a download first, really strange
Rampz
Well-known member
Success i have had to Query track numbers twice, one at initial start up and after couple of seconds later before getting to play song, now it shows correctly and plays correctly on OLED and Terminal even after a cycle of the power.
My wife asked me just now if i was trying to mess with her brain today, i was playing with code before work, i seemed to be getting somewhere, but struggled with above issues, told her i left it playing on low and left for work, only to find it has ended up playing the same track for 12 hours, she wasn't impressed
tmfkam
One problem you may have is that the track number value(s) are returned as two bytes. You may have to reference TrackNum.msb and TrackNum.lsb to get a word value?
There is also a value returned that indicates "success" in retrieving the value(s). I'll have to dig out my code and see what I noted about track numbers, I'm sure there was something odd but can't recall.
I do recall sometimes only getting "1", again I think a few subsequent calls were needed but I'll have to think about it.
Rampz
Well-known member
A strange affect tmfkan, seems i am getting away with receiving twice into TrackNum rather than TrackNum.msb and TrackNum.lsb , i assume it returns into b8 and the second time into b9 making up w4, i noticed previously if i cycled power i must have only ever received b8 part only, which would be 1 and if i cycled power a second time with it resetting the picaxe i assume i got b8 the second time, but if i then did a download of code then the program started again i maybe got b9 section, being 14, after a download it always seemed correct, so maybe the download didn't clear b8, i would have thought a download would have reset all ram memory? i never tried cycling power and doing a download straight away to make it read only once.
I did just turn it off, remove the last track from the usb and powered up and it read correctly, i did just try removing the usb mid song, it starts counting up the track number and not finding anything, re iserted usb and after a few seconds started playing at the next number it found, so thats ok.
Maybe a bit difficult to try and get the "play song" to stop and reset the counter and wait for the usb to be re inserted?
If it gets a Pull-out of the device this is the string 7E FF 06 3B 00 00 02 xx xx EF, after inserted its 7E FF 06 3A 00 00 02 xx xx EF, it works fine but would be a nice touch to recount number of tracks and start from the beginning etc
Thinking further if we receive a TV card inserted and get it to reset everything that could do it?
Another thought i am using cmd = $47 which is to receive data from the TF card but i am using USB, but as you said i din't have to set it to USB?
Below is my code as it stands now
#picaxe 14m2
#no_data
#terminal 4800
Symbol TX = B.4
Symbol RX = C.3
Symbol cmd = b0
Symbol arg.lsb = b2
Symbol arg.msb = b3
Symbol Track = w2
symbol Vol = b6
Symbol Pressed = 1
init:
cmd = $47
Gosub Receive
Pause 2000
'pause 3000
cmd = $47
Gosub Receive
pause 2000
Pause 1000
Gosub playsong
playsong:
    'cmd = $47 'Query TrackNum a second time helps
    'Gosub Receive
    Pause 1000
    Pause 100
    pause 50
    Gosub volumeup
    pause 50
    Gosub volumedown
    pause 50
    Gosub playnext
    Loop
    next
    Pause 1000
Send:
SetFreq BAUD_FREQ
Pause 10
SetFreq MDEFAULT
Return
Receive:
SetFreq BAUD_FREQ
  Pause 10
  SetFreq MDEFAULT
  Return
volumeup:
Volumedown:
        vol = Vol min 1 - 1
playnext:
       Track = Track + 1
       pause 500 ' Needed to stop double song issue, but slowed skipping song down
tmfkam
Here's the code I'm using.
It looks as though I request track info for the various devices in turn. Without checking I seem to think that the query for uSD will work for a USB disk, if there is no uSD fitted. It's been a while though since I wrote any of this and I could have "mis-remembered".
As before, this has been written in a different variant of BASIC, but should give you an idea...
SerialData() is an array of Byte values. You might just as easily replace this with b1, b2, b2, b4... and so on.
I found it clearer to actually send the values in each command as it made it easier to understand what each command was doing, and where the differences were.
Sub Fetch_Tracks
    SerSend 1, 0x7e
    SerSend 1, 0xff
    SerSend 1, 0x06
    SerSend 1, 0x48 'Command for track query uSD disk
    SerSend 1, 0x00 'Return value request
    SerSend 1, 0x00
    SerSend 1, 0x00
    SerSend 1, 0xef
    Serial_Fetch
    'If there are no tracks (folders) found on uSD, try USB
    If ReturnTracks < 1 Then
        Wait 100 mS
        SerSend 1, 0x7e
        SerSend 1, 0xff
        SerSend 1, 0x06
        SerSend 1, 0x47 'Command for track query USB
        SerSend 1, 0x00
        SerSend 1, 0x00
        SerSend 1, 0xef
        Serial_Fetch
    End If
    'If there are no tracks (folders) found on USB, try Flash disk
        Wait 100 mS
        SerSend 1, 0x7e
        SerSend 1, 0xff
        SerSend 1, 0x06
        SerSend 1, 0x49 'Command for track query Flash disk
        SerSend 1, 0x00
        SerSend 1, 0x00
        SerSend 1, 0xef
        Serial_Fetch
    End If
    Wait 100 mS
End Sub
Sub Serial_Fetch
    Let ReturnTracks = 0
    SerReceive 1, SerData(1) '0x7e
    SerReceive 1, SerData(2) '0xff
    SerReceive 1, SerData(3) '0x06
    SerReceive 1, SerData(4)
    SerReceive 1, SerData(5)
    SerReceive 1, SerData(6) 'High Byte of track count
    SerReceive 1, SerData(7) 'Low  Byte of track count
    SerReceive 1, SerData(8) '0xef
'    Locate 1, 0
'    Print SerData(4)'Indicates disk? 72=microSD 71=USB?
'    Print ":"
'    Print SerData(6)
'    Print ":"
'    Print SerData(7)
'    Print "                "
'    Wait 1000 mS
    If SerData(6) > 0 Then
          Let ReturnTracks = SerData(6)
          Let ReturnTracks = ReturnTracks * 256 'High Byte
    End If
    If SerData(7) > 0 Then
          Let ReturnTracks = ReturnTracks + SerData(7) 'Low Byte
    End If
End Sub
JaneWat
New member
I have been asked if i can add a Cockrill sound to an animated display, always looking for opportunities to use the picaxe's now, it seems the store is out of Vmusic2 modules so i have ordered one from RS, Firstly what the best picaxe to control it with i have the AXE091 board and it came with a 18m2 that i have never used, is it suitable to control the Vmusic2? So far i have only used the 08m2. Is the Vmusic2 they way to go to add a single mp3 to a project? I did see the french part of the forum speak about a Vmusic3?
The cockrill will need to be quite loud so i will need an external amplifier with volume control
Not asking for help just want to discuss options really at the moment
listen, well, if these guys succeed
, then you will definitely succeed
The first code is correct. The second code will not work correctly when there are 256 tracks or more.
The best way to get the track count into a word variable 'TrackNum' would be -
TackNum = arg
