Yes, the original purpose of this thread was to find some alternatives to a external dac-chip...
In last two weeks I have also done a little something on the matter:
-Took a industrial valve-adjuster (input 0-10V) and tested both those circuits, that were shown in the beginning of this thread. In that application BOTH worked just like expected. But as "the court" said, one can not draw conclusion about that ; the circuits still are not suitable to any other app...
I will later re-engineer the valve-adjuster and try to see, what kind of signal conditioning (if any) is used in it. Will report on that.
-Have also searched the Internet for a suitable ONE_CHIP external dac (output 0-10V, single supply)
Reading those datasheets and app-notes have been a good lesson.
In this, again, I search for simplicity:
-single supply
-no extra op-amp needed to gain 0-10V
Findings: most single-supply ones does NOT reach rails... closest is Vss+0,3V. On the Vdd side that is no problem, it can fixed by feeding 10,3V...
0 and 10V can be reached by adding a negative feed, and that can be "extracted" from single supply with one chip, but that makes two chips together
(as does dac+op-amp)
Conclusion: no VERY simple solutions available there... (or just I haven't found the right chip since)
BTW: I was surpriced to find several "commercial" serial-driven 0-10V dac-modules ,
that use simple op-amp as outputs. All of those were guaranteed to be accurate and fast...
So, the op-amp -way seems not to be any worse than a "real" dac-chip.
(all those seemed to have a uP to handle the serial side, and pwm:ing the op-amps)
