Very quick qestion regarding 40x2 pins
Steve2381
Hi all
Just designing a new project and I appear to have PDF blindness! I can't find the answers I need.
If connecting this LCD screen to a 40x2 using serial, I assume I need to use Pin 18 for SCL, pin 23 for SDI and pin 24 for SDO.
http://www.mouser.com/ds/2/291/NHD-0420DZW-AB5-247046.pdf
Also, can I use any input/output pin for serin and serout commands, or are they only available on certain pins?
The SPI-style communication seems to use a 10-bit data transfer mechanism so seems unsuitable for using the hardware SPI hardware of a PICAXE 40X2. You would have to bit-bang the SPI so it could use any pins.
Yes, SERIN and SEROUT can be used on any pins which can be used as digital I/O ( with a few caveats to that if one wanted to be pedantic ).
Steve2381
Mmm... glad I asked. Thanks Hippy.
Trying to find a blue Oled display that I can run off a 40x2... but I am really low on spare pins.
Also... no idea how to bit bang!
Steve2381
I need a 4x20 display eclectric.. if I can find a suitable blue Oled, then I could possibly use the serial driver board.
I have redesigned the circuit and managed to get enough pins to run the original display I found in 4 bit Parallel mode... any reason that would not work?
Should work okay in 4-bit mode, and if you ask nicely and someone has the time I am sure they could write a bit-banging routine for you.
