Evening All,
Just after a spot of help with a small part of my code im trying to come up with.
I want to make a RGB programme that slowly fades from one color to another, I have a push button switch that I will be using inorder to change the how quickly the change occurs and wondered how I would set up the variable in the code so that is could read how many times the button had been pressed and therefore what speed it should be running it. I plan to have say 10 speed setting, so once the variable reaches 10, is it possible to make it start again back at 0?
Thanks
Thanks
