Var Byte query
LED Maestro
Hey all, I found this code, open source for a project i am doing. the original editor used a ds1307, max7221 and a picaxe 28x2 all of which i am also using in my project. I downloaded the code but whilst loking through i noticed lines of code that consisted of Var byte labels. I have never come across this when programming before, at least not in basic programming. I was wondering how i could convert these to symbols. I have included the code below. I am basically reading the time from the rtc, shifting it to the pic and then o/ping to the 7221 to display on 7 seg displays.
any help is greatly appreciated. I have already spent several hours on google trying to solve it myself. I have managed to change a few of the first instances of the var byte code into standard symbol definitions.
REM target device: PIC28X2
REM peripherels: MAX1307 RTC and MAX7221 Display driver
pause 100
symbol temp0=b0
symbol temp1=b1
symbol i=b2
'pin assignments###########################
'PGD var portb.7 'in circuit programming pins
'PGC var portb.6 'do not need to declare these
'PGM var portb.3 'so i just note them here.
'data communication
symbol dout=C.5 'data out
symbol din=C.4 'data in to
symbol dclock=C.3 'clock for data
symbol s7221=C.0 'chip select LED driver
symbol s1307=C.1 : low s1307 'chip select RTC
symbol debugLED=C.7 'i can blink this led to check code
'RTC chip#################################
clockmin var byte : clockmin = %00000000 'default hours are 12
clockhour var byte : clockhour = %01010010 'in packed binary coded decimel
'setup addresses
rmin var byte
rmin = $01
wmin var byte
wmin = $81
rhour var byte : whour var byte
rhour = $02 : whour = $82
'set control register
high s1307
shiftout dout, dclock,1, [$8F,%00000011 ]
low s1307
pause 50
high s1307 'set clock to default time
shiftout dout, dclock,1, [wmin]
shiftout dout, dclock,1, [setmin]
low s1307
high s1307
shiftout dout, dclock,1, [whour]
shiftout dout, dclock,1, [sethour]
low s1307
'LED driver#############################
digit0 var byte : digit0 = 1
digit1 var byte : digit1 = 2
digit2 var byte : digit2 = 3
digit3 var byte : digit3 = 4
row4 var byte : row4 = %00000001
dots var row4.0
'set decode to decode numbers or set LEDs individually
low s7221
shiftout dout, dclock, 1, [%00001001,%00001111 ]
high s7221
'set intensity of LEDs
low s7221
shiftout dout, dclock, 1, [%00001010, %00001111]
high s7221
'set scan limit - how many digits
low s7221
shiftout dout, dclock, 1, [%00001011, %00000100]
high s7221
'turn driver on (shutdown mode = off)
low s7221
shiftout dout, dclock, 1, [%00001100, %00000001]
high s7221
'test LEDS
for i = 1 to 3
low s7221
shiftout dout, dclock, 1, [%00001111, %00000001]
high s7221
high debugLED
pause 100
low s7221
shiftout dout, dclock, 1, [%00001111, %00000000]
high s7221
low debugLED
pause 50
next
gosub display
pause 500
'the main loop###################################
	gosub display
	gosub readclock
	gosub converttime
'subroutines####################################
converttime:
digit0 = clockmin & $0F
digit1 = (clockmin & $F0) >> 4
digit2 = clockhour & $0F
digit3 = (clockhour & $10) >> 4
readclock:
high s1307
shiftout dout, dclock,1, [rmin]
shiftin din, dclock,2, [clockmin]
low s1307
high s1307
shiftout dout, dclock,1, [rhour]
shiftin din, dclock,2, [clockhour]
low s1307
display:
	if digit3 = 0 then
		digit3 = 15
	for i = 0 to 4 'output each digit one at a time
		lookup i, [%00000001,%00000010,%00000011,%00000100,%00000101],temp0
		lookup2 i, [digit0,digit1,digit2,digit3,row4],temp1
		low s7221
		shiftout dout, dclock, 1, [temp0,temp1]
		high s7221
	next
	if digit3 = 15 then
		digit3 = 0
srnet
Cant see how the 'original' would have been for a PICAXE, since you have already discovered you get syntax errors for;
clockmin var byte
Because the editor does not recognise the format.
You presumably need to convert lines like above to;
Symbol clockmin = b10
or similar.
Concur with srnet.
Could have been some B.Stamp code or similar that someone ported on paper but never tested.
Can be the case when grabbing code from the internet.
The RTC states 1307 but a quick glance at the code suggests a serial/SPI comms for the 1307 and 7221 chips with chip select lines and SHIFTOUT commands so not an i2c DS1307.
I would also guess the code was originally for a Basic Stamp or similar. There is quite a lot in there that probably has to change to make it work on a PICAXE but for the VAR variable allocations -
clockmin var byte
for PICAXE that would become -
symbol clockmin = bX
Where X would be a number which makes the variable unique to any other variable used in the program.
LED Maestro
Thanks. I figured as much that the code was not originally for picaxe which made me have another look into the manuals and the internet as I became confused (Not hard to confuse me ha). Thanks for all the advice. And westaust, I forgot to add my comms code for i2c data transfer between the pic, the RTC and the 7221. I will be using that rather than the shiftout command.
Again, thank you very much!
