Using PVC160205PT LCD Display
Pekari
Hi!
Where I can found pins and code information of this display?
I try to connect it to board like AXE033 but it will not work with it.
Pekari
It seems to be a the same standard pins. I don't know why it will not work. It worked when it was in the device.
john2051
Hi, if the datasheet i found is anything like accurate,
the backlight pins are pins 15 & 16 whereas i think they
are the other end on the axe033. On mine pin 14 is printed
the opposite end of the backlight pins.
Hope this helps..
regards john
It would be helpful to others in solving your problem if you:
1. Posted a link to adatasheet forthe LCD
2. Posted a schematic showing how you have it connected
3. Posted the PICAXE code you are trying to use.
4. Maybe a clear photo taken straight on (perpendicular) showing the wiring clear enough for others to follow.
Keep in mind that you have all of the information in front of you.
Others have to guess what the problem could be without good information.
