Using opto-isolator with picaxe
#2
Diode-mixing two PICAXE outputs should not be a problem and picoamp reverse currents should not be an issue.
Check that the current sourced by the output pins is below the recommended limit; the 110R current limiting resistor feels a little low but may be acceptable depending on components used.
