Using angular velocity to get angle of displacement
Denzel
I have a set of Pinpoint Gyro's:
http://www.pinpoint-gyro.com/wp-content/uploads/2010/06/PinPoint-CRM200-00-0100-132-Rev1.pdf
That I am trying to measure an angle of displacement from a set angle.
If I have angular velocity how do I convert this into an angle (degrees)
do I simply use omega = dtheta/dt? and do a radian to degree conversion?
Im unsure as to how to continually find the angle between the initial reference position and the current position repeatedly at say 1 second intervals.
Not this is not a code question its more of a theoretical question, Once I understand the method, the code will follow.
Any help would be much appreciated
Denz
