southernbob
I have one IR receiver working good, going into the Infrain pin on a 08M. I am using a remote control unit to send the codes and displaying the received code on the "terminal" function. I would like to use 2 IR receivers mounted back-to-back (1 pointed forward the other pointed backward) to give a 360deg detection area. I was wondering whether I could tie (dot-OR) the 2 output pins together going into the Infrain pin on the 08M. My concern is both electrical and if both receivers receive the IR code whether that would "upset" the 08M getting the correct code. The receiver is connected as shown in the manual for the Infrain2 instruction. The other possiblity is to run each IR receiver output into an OR circuit or just use one IR receiver and use reflectors of some type to route the IR from the back to the front. The signal from the remote seems fairly strong as I can bounce it off the ceiling and still have it detected. I haven't tried any type of distance test. Thanks for any input.
