cactusface
I have to confess that the original idea for this was not mine, my mate Peter Taylor who has had many years experience playing with electronics, but only a little with the picaxe. Peter came up with this idea for a small PCB that would carry an 08 Picaxe with power and the download circuits, also included were header contacts (Sockets really) to allow easy connection to a breadboard via wire links, even the power headers (fitted upside down) plugged in to the breadboard power rails, and thus power the board too.
I initially copied this but my BB (=Breadboard) had the power rails at the top and bottom, not on the sides as his, so I had to modify my PCB making it a bit longer. With the extra space, could I also fit a 20pin socket in there? But then I noticed that the top 4 pins of the 08 Picaxe and 20 were the same. So just by fitting a 20pin socket you could program both sizes, then the next day I discovered that the 14pin devices also fit with the same top 4 pins providing the power and Sin and Sout on identical pins.
The other mod I made to Peter's circuit was to add a 2 pin header for battery connection and flip the socket strips so all 8 pins/contacts also plugged directly into the BB! But on the 20 pin version I thought that all 20 pins making contact directly onto the BB was just a bit over-kill. I have all the Diptrace schematic and PCB files, if anyone want's to try it.
Nice useful project for a starter perhaps?
Hope it's useful.
Regards
Mel.
Hope it's useful.
Regards
Mel.
