I'm making battery powered project where I'm using URF anf ERF modules. I measured that those boards(I tested ERF) are using 20-25mA current when they are powered on. Regarding the datasheet URF, ERF and XRF modules are using Texas Instruments CC1110 chip which sleep mode current should be 300nA. In XRF module there is sleep pin but not in ERF and URF. Instead of sleep pin there is cts pin. When cts pin is low the current is about 25mA and in low state it's about 20mA. So.. is it possilble to program those board using PE6 configuration wizard so that sleel mode could be used on those boards?
