I heard that you can under clock the picaxe to run at lower voltage. Does under clocking give it a stable voltage? The picaxe 08m uses its source power as a reference when doing readadc. Will it give the same value if I use a voltage between 2.8v-5v?
For example i want to read the voltage of a 1.5v pot(not sure how many ohms it is). If I run the picaxe normally then the readadc value of the pot will change depending on the level of my batteries. If I under clock the PICAXE will I get the same value even if my batteries are low or fully charged?
