uM-FPU I2C problem
Mike_cj0
Sorry, it's me again with another problem. I imagine you all must be getting tired of seeing posts started by me!
After successfully getting the FPU running on bread board and communication via serial cable to the IDE i moved on to the next step and fitted a 28x2 to the bread board and linked it to the FPU via I2C with a 4k7 resistor on each of the two connections.
I set the MCLR and CS pins high on the FPU to set it to I2C mode. All FPU settings are still on the factory defaults.
I downloaded the following program to the 28x2
Hopefully what i have pasted below will still work as i have had to delete a lot of the unused definitions so it was short enough to post. I'm hoping in my haste to post this i have not deleted something that is needed.
'-------------------- uM-FPU V3.1 I2C definitions ------------------- 2011-10-17
symbol	fpuID		= 0xC8	' uM-FPU I2C address
'-------------------- uM-FPU V3.1 opcode definitions ---------------------------
symbol	SYNC		= 0xF0	' Get synchronization byte
symbol	READSTATUS	= 0xF1	' Read status byte
symbol	READSTR	= 0xF2	' Read string from string buffer
symbol	VERSION	= 0xF3	' Copy version string to string buffer
symbol	READVAR	= 0xFC	' Read internal variable, store in reg[0]
symbol	SYNC_CHAR	= 0x5C	' sync character
'-------------------- uM-FPU variables -----------------------------------------
symbol	dataByte	= b13		' data byte
symbol	format	= b13		' format (same as dataByte)
symbol	statusByte	= b13		' status byte (same as dataByte)
'==================== end of uM-FPU V3.1 I2C definitions =======================
'-------------------- main routine ---------------------------------------------
	pause 5000				' wait for terminal window
	sertxd (13, 10, 13, 10, "template", 13, 10)
	sertxd (13, 10, 13, 10, "SYNC_CHAR 1 - ", SYNC_CHAR)
	gosub fpu_reset			' reset the uM-FPU
	sertxd (13, 10, 13, 10, "SYNC_CHAR 2 - ", statusByte)
	if statusByte = SYNC_CHAR then
	  gosub print_version		' display the uM-FPU version number
	  sertxd (13, 10, "uM-FPU not detected.")
'	(insert application code here)
'	hi2out, 0, (...)
done:
	sertxd (13, 10, "Done.")
	end          			' end of program
'-------------------- uM-FPU V3.1 I2C support routines -------------- 2011-10-17
fpu_reset:
	hi2csetup i2cmaster, fpuID, i2cslow_8, i2cbyte
	sertxd (13, 10, "send reset")
	hi2cout 1, (0)			' reset the uM-FPU
	pause 10				' wait for reset to complete
	hi2cout 0, (SYNC)			' check for synchronization
	goto fpu_readStatus2
fpu_wait:
	hi2cin 0, (statusByte)		' wait for ready status
	if statusByte <> 0 then fpu_wait
fpu_readStatus:
	gosub fpu_wait			' read status byte
	hi2cout 0, (READSTATUS)
fpu_readStatus2:
	hi2cin 0, (statusByte)		' read status byte
print_version:
	hi2cout 0, (VERSION)		' get the uM-FPU version string
	goto print_fpuString		' print it
print_float:
	format = 0				' set for free format
						' (fall through to print_floatFormat)
print_floatFormat:
	hi2cout 0, (FTOA, format)	' convert floating point to formatted ASCII
	goto print_fpuString		' print the string
print_long:
						' (fall through to print_longFormat)
print_longFormat:
	hi2cout 0, (LTOA, format)	' convert long integer to formatted ASCII
						' (fall through to print_fpuString)
print_fpuString:
	gosub fpu_wait			' wait until uM-FPU is ready
	hi2cout 0, (READSTR)
print_string2:
	hi2cin 0, (dataByte)		' display zero terminated string
	if dataByte = 0 then Print_String3
	if dataByte > 127 then Print_String3
	sertxd(dataByte)
	goto Print_String2
print_string3:
	return				' end of string
'==================== end of uM-FPU V3.1 I2C support routines ==================
The code is basically the standard FPU template file but with the I2Cfast in the setup changed to I2Cslow_8. I have als added a few extra serial out commands to see what's going on.
What i see on the terminal is the following
template
SYNC_CHAR 1 - \
SYNC_CHAR 2 - É
Done.
(The É isn't what i'm seeing in the terminal! it's more of a 90 degree right pipe and in hex is 0xc9 i think after looking it up in an ascii list)
Sync_char 1 is what is meant to come back and sync_char 2 is what is actually coming back.
As you can see what's coming back isn't what is expected.
I have tried changing the I2C speed from fast to slow and no change. Also initially i was using I2CFast and not I2Cfast_8 but the result was still the same.
Clearly something isn't right with either my code or my wiring or both. Unfortunately i don't own a scope or even a logic probe. just a multimeter so i think debugging this is going to be a pain.
Can anyone see anything wrong with the code or suggest what else could be wrong?
Many thanks
Mike
papaof2
Check the state of FPU pin 4. It should be in a different state (high/low) for slave operation via the PICAXE than for standalone programming. Sorry I don't remember which level is which - my schematic has a 4K7 to +5 and a switch to ground to chnage modes.
John
Mike_cj0
I checked those pins and both were high.
I have found the problem though and it is now working.
It turns out the SDA wire had a break in it, when i replaced the wire it all worked. Last night i only checked the voltages at the FPU end of the I2C wires which is also the end of the buss that i have put the 4k7 pull up resistors. I didnt think to check the other end. Today i went through checking everything and found the broken wire.
It now works as expected.
Sorry for wasting peoples time. i should have checked it better before posting. I promise i shall leave you all in peace for a while now!
