OmgItsHeaven
I have been building an obstacle colliding robot. I previously asked for help regarding this, but since it was on a different topic I opened a new thread. So my problem is that every now and then my range reading is dropping to 4 then back to the correct reading. (The number isn't always four it could be 7 or 8). From the video I have linked you could see that.
The PICAXE and the motors have different power supply to reduce the power fluctuation affecting the sensor.
Could you please help me
symbol trigPin = B.1 ;Assign pin B.1 to a variable called trigPin
symbol range = w1 ;Create a variable called range stored in w1
symbol currentsense = w0 ;Create a variable called currentsense stored in w1
symbol BuzzerPin = B.0 ;Assign pin B.0 to a variable called trigPin
;Motor Control Pin
symbol LForward = B.2 ;Assign pin B.2 to a variable called LForward
symbol RForward = B.4 ;Assign pin B.4 to a variable called RForward
symbol LBack = C.0 ;Assign pin C.0 to a variable called LBack
symbol RBack = C.2 ;Assign pin C.2 to a variable called RBack
;Limit Variable
symbol MotorLimit = 48 ;Stores the maximum safe current limit in a variable called MotorLimit
symbol targetrange= 30 ;Stores the maximum distance the robot will see an object and collide with.
symbol MotorPower = 797 ;Stores the duty (The power of the motor)
symbol SafeDistance = 15 ;Stores the minimum distance the robot will backaway when it is going backward due to currentsense
start0: ;Label, state the start of a parallel task, Initiliase the pwmout. (Only goes once).
pwmout LForward,150,0 ;Initiate a pwm output on pin LForward with a period of 150 and a duty of 0.
pwmout RForward,150,0 ;Initiate a pwm output on pin RForward with a period of 150 and a duty of 0.
pwmout LBack,150,0 ;Initiate a pwm output on pin LBack with a period of 150 and a duty of 0.
pwmout RBack,150,0 ;Initiate a pwm output on pin LBack with a period of 150 and a duty of 0.
start1: ;Label, state the start of a parallel task, (Constantly check the range using the ultrasonic and readadc pin B.3 for currentsense.
readadc B.3,currentsense ;Reads the analogue value from pinB.3 and convert it to a digital value (Which the PICAXE understands) and stores it in a variable called currentsense.
ultra trigPin,range ;Initiates the SRF005 Sensor, uses the trigPin to pulsin and pulsout, convert the raw distance into centimeters and then store in variable called range
debug
goto start1 ;Goes back to the subsection "start1"
start2: ;Label, state the start of a parallel task, makes the robot move forward, while it is looking for object to collide with.
pwmduty LForward, MotorPower ;Changes the duty on pin "LForward" by "MotorPower"
pwmduty RForward, MotorPower ;Changes the duty on pin "RForward" by "MotorPower"
pause 1000 ;Waits 200 ms
pwmduty RForward, 0 ;Changes the duty on pin "RForward" to 0
pause 500 ;Waits 100ms
goto start2 ;Goes back to the subsection "start2"
start3: ;Label, state the start of a parallel task, make the robot go forward and collide when it sees an object that is less than "targetrange" 30cm away from it.
do while range < targetrange AND range > 3 ;Code loop while range is less than targetrange AND while range is greater than 3
suspend 2 ;Stops start2
suspend 4 ;Stops start4
pwmduty RForward, MotorPower ;Changes the duty on pin "LForward" by "MotorPower"
pwmduty LForward, MotorPower ;Changes the duty on pin "RForward" by "MotorPower"
loop while range < targetrange AND range > 3 ;Codes loop while range is less than targetrange AND while range is greater than 3
resume 2 ;Starts start2
resume 4 ;Starts start4
goto start3 ;Goes back to the subsection "start3"
start4: ;Label, state the start of a parallel task, make the robot go backwards and make sound when currentsense is above the current threshold.
if currentsense >= MotorLimit then
pause 100
suspend 3 ;Stops start3
pwmduty LForward,0 ;Changes the duty on pin "LForward" to 0
pwmduty RForward,0 ;Changes the duty on pin "RForward" to 0
do while range <= SafeDistance ;Code loop while range is less than or equal to SafeDistance
pwmduty LBack,MotorPower ;Changes the duty on pin "LBack" by "MotorPower"
pwmduty RBack,MotorPower ;Changes the duty on pin "RBack" by "MotorPower"
high BuzzerPin ;It give 5v to the BuzzerPin
loop while range <= SafeDistance 'Code loop while the range is less than or equal to SafeDistance
pwmduty RBack,0 ;Changes the duty on pin "LBack" to 0
pause 500 ;Waits 200ms
pwmduty LBack,0 ;Changes the duty on pin "RBack" to 0
low BuzzerPin ;Give 0v to the BuzzerPin
resume 3 ;Starts start3
else goto start4
else goto start4
goto start4 ;Goes back to the subsection "start4"
